AC light flashing and cricket sound post engine swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skier67, Sep 28, 2019.
  1. Sep 28, 2019 at 4:15 PM
    skier67
    skier67 [OP] New Member
    2011 TRD Sport
    2" spacer lift
    Got a bit of a mystery on my hands and would love any input:
    I recently got an engine swap done in my 2011 (long story involving a rock and a destroyed radiator). Same V6 4L as before just lower miles on it. Mechanic did a stellar job as far as I can tell however!... AC light is blinking when activated and blowing warm air. More concerning though is that the truck is also making a cricket like chirping sound when accelerating but that goes away after about 15min of driving. Occasionally the AC light will stop flashing and just blow warm air. No smell or other sounds to speak of. Maybe serpentine belt? AC compressor? Thanks for any advice!
  2. Sep 28, 2019 at 5:54 PM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Blinking light usually means low on Freon , have the system checked for leaks and recharge .
    skier67[OP] likes this.
  3. Sep 28, 2019 at 6:02 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I believe a blinking light means a discrepancy between the engine (belt) speed and AC unit speed has been detected. Could be a clutch issue, a speed sensor issue on the compressor (think those are know to be faulty on certain year 2nd gens) or maybe not enough refrigerant like turbosnail said.
    There's some good info about all of those problems on here.. I'll see if I can remember to dig up one of those threads later when I'm out of the shop
    skier67[OP] and turbosnail like this.
  4. Jan 18, 2020 at 12:49 PM
    Tommyboy222
    Tommyboy222 Active Member
    Tom
    2017 TRD OR MGM
    Kind of late response but check to see if the clutch is not engaging. My truck I had to replace the ac clutch a $30 part because the rubber breaks down after time
    SR-71A likes this.
