ac light flashing, consistently after 3 seconds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by carlsson1, Oct 26, 2024.
  1. Oct 26, 2024 at 11:19 AM
    carlsson1
    carlsson1 [OP] Member
    kurt
    2008 2.7 5 speed
    2008 4 cylinder tacoma, ac light flashes after 3 seconds every time i turn on ac, never been intermittent. i replaced the compressor with reman unit, had system evacuated before and professionally recharged, tried 3 different lock up sensors, tested one - ok, magnetic clutch relay is fine, replaced ac amplifier with new toyota. seems like everything that is listed on posts here, but none corrected problem. ac works fine when i use a jumper wire in place of the clutch relay, but very inconvenient to install every time i need ac on. ive wanted to install a switch instead of using a jumper wire, but not sure where wiring needs to be grounded to turn on clutch, except at relay, but difficult to add a wire to relay recepticle where relay needs to be plugged in place. if anyone has any ideas on what else would cause this constant problem, or can advise me what wire in wiring harness near amplifier or relay box, can be grounded to turn clutch on would be very helpful.
  2. Oct 27, 2024 at 9:18 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What did you do with the Original Toyota sensor.
    It has often been an issue with aftermarket sensors not working properly.
    Install an OEM Sensor and it will probably work.
    Dm93 and b_r_o like this.
  3. Oct 27, 2024 at 10:53 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    In my experience only the OEM lock sensor will work
    Dm93 and Jimmyh like this.
  4. Oct 27, 2024 at 8:33 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked circuit integrity between the Lock Sensor and A/C Amplifier?
    You don't want to just add a switch to force the compressor on because that would defeat both the high pressure cutout and evaporator freezup protections.
    Jimmyh likes this.
