Ac light Flashing???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Millertime187, Jun 23, 2013.
  1. Jun 23, 2013 at 7:18 AM
    Millertime187
    Millertime187 [OP] I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I have a 2012 taco that I've had less than a year. This week my AC light will flash when I first start my truck. If I turn it off and back on it works fine(the ac button)? I have 35,000 miles on my truck already and assuming I have only a 1000 miles left on my warranty, but my problem is I work so much it hard for me to get to dealer, ( 50 miles away one way). So my first question when you buy a new truck with the warranty is it 36,000/two year, is it what happens first or am I about out on my warranty? I bought it new last Aug. or do I need to take a day off work for my ac?
    Thanks,
    David
  2. Jun 23, 2013 at 7:22 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I cannot answer your question, but I suggest that you consider an extended warranty. I got the platinum with 100,000 miles and 7 years no deductible. It cost me around 1250 dollars.
  3. Jun 23, 2013 at 7:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Take it in. This issue can be low coolant, or a bad compressor.
  4. Jun 23, 2013 at 8:12 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Easier said than done! I am maintenance at a pharmaceutical factory and we are on shut down next few weeks, with weekends and long hours. But my other question when is my warranty up? In a 1000 miles or another year? Cause I've heard both ways?
    Thanks!
  5. Jun 23, 2013 at 8:14 AM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    Your warranty works on which ever you hit first
  6. Jun 23, 2013 at 8:29 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    That's what I was thinking.
  7. Jun 23, 2013 at 8:56 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would suggest figure our a way to get it in our purchase the extended warranty before you hit 36k miles.
  8. Jun 24, 2013 at 7:10 AM
    Jeffro51
    Jeffro51 Active Member
    jeff
    nw washington
    08 dc 4wd 6sp
    If your ac light is blinking it may be the ac relay, a $ 70 part. That what it was on my camry. I had a extended warranty and never used it, wasted money.
  9. Jun 24, 2013 at 9:13 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    I'm going to try best to get it there this week. Yea I hate going to dealer so I'm good with out the extended warranty. I just recorded it flashing for the stupid dealer if they say they can't make it do it.
  10. Jul 19, 2013 at 1:47 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Any update on this? My 2010 just started doing this about a week ago.
  11. Jul 19, 2013 at 1:56 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Mine stopped doin it and I'm past my warranty now so I hope it never comes back. Mine flashed probably a out 5-7 different times in a week period, but hasn't done it sense. I went to dealer and I hate that place so I left after a few kind words. Sorry no help here.
  12. Jul 19, 2013 at 2:12 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    Yeah mine only does it every so often. But it takes a while now for it to start working even when turning the a/c all the way off and down. Seems like the only way I can get it to keep the a/c on after the truck sitting for a few days is turn the a/c off then turn it on high.
  13. Jul 19, 2013 at 3:17 PM
    Kenny Powers
    Kenny Powers Harmful if swallowed
    Seth
    Northern BC, Canada
    2013 + 2002 tacos
    Mine did that when the compressor gave out
  14. Jul 19, 2013 at 3:20 PM
    169.254.255.201 Well-Known Member
    Interwebs
    if you purchase a warranty, search on here for who to buy it from. I forget the dealership, but they evidently have really good prices.
  15. Jul 19, 2013 at 7:35 PM
    DocHolliday
    DocHolliday Well-Known Member
    Charleston SC
    13 PreRunner SR5
    It's not an exact problem in particular. But it is flashing to let you know there is a problem with the AC system. Get it to a shop and have checked out is best answer, b4 you throw money and parts at it and not fix it.
  16. Jul 19, 2013 at 9:08 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    mine too. I fixed mine myself.
  17. Jul 19, 2013 at 9:11 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    When going through deeper water my A/C light will flash and go hot after awhile, turn if off a few mins for things to dry out and everything's back to normal.
  18. Jul 19, 2013 at 9:37 PM
    Elk
    Elk Active Member
    '07 Quad Cab Shortbed 6spd
    FJ Cruiser Wheels
    ^^^^ This is my case.
    My AC light flashes after the truck runs through a deeper puddle. I switch the AC off, then back on and it goes away after about 10 seconds.
  19. Jul 19, 2013 at 10:22 PM
    Khaos
    Khaos Big Member
    Bryant
    Hmm. Been wondering what it was.
    It only happens after continuos semi-deep water or after something door level or higher. I usually turn the A/C off before deeper water to try to prevent it. It's not doing damage I hope?
  20. Jul 20, 2013 at 4:55 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    This is the case with mine too. In order to get to work I have to drive down a road with a foot plus of water.
