AC Lines coming from cab / heat sheilding on the Low side line?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jammer, Aug 6, 2020.
  1. Aug 6, 2020 at 11:01 AM
    jammer
    jammer [OP] 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Would there be any benefit in ac cooling if the ac lines coming out of the cab to the compressor were wrapped in a heat shielding sleeve??
  2. Aug 6, 2020 at 11:05 AM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    I never considered that, if you do it. Please report back. The high side line will be hot, I'd probably skip wrapping that one.
    Are you having trouble cooling the truck down?
    jammer[OP] likes this.
  3. Aug 6, 2020 at 11:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I doubt it would get you much in such a short distance.
    If the evap coil was at the tail gate it might be a considerable saving
    That said it is not going to hurt .
    Keeping the Condenser clean would help more .
  4. Aug 6, 2020 at 11:21 AM
    jammer
    Ben
    Bentonville, AR
    Not really. I was just trying to think of some ways to help the system. Good call on the "high side line". My wife has a Nissan Altima and the lines are exposed on it as well, so maybe that's the best way.
  5. Aug 6, 2020 at 11:27 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    More of a assembly line thing the line gets stopped enough .
    It would be a pain to wrap .
  6. Aug 6, 2020 at 8:01 PM
    Glamisman
    Glamisman Well-Known Member
