AC Magnetic Clutch Fan Relay Substitute/Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Caster, Apr 2, 2018.
  1. Apr 2, 2018 at 7:35 PM
    Caster
    Caster [OP] Active Member
    2008 Tacoma 4.0 SR5 Prerunner Off Road Access Cab 2WD
    None
    Is there a relay in the fusebox of my 2008 4.0 that can be subbed for the magnetic clutch fan relay? The clutch fan relay is the only grey one. All of the others that are the same size are blue. Is there one that can be subbed safely to help see if my clutch fan relay is bad? I definitely don't want to sub an incorrect one and cause a problem. Thank you.
