ac/motor now only works on high
Discussion in 'New Members' started by cornhusker rich, Sep 1, 2015.
  1. Sep 1, 2015 at 7:36 PM
    cornhusker rich
    cornhusker rich [OP] New Member
    Rich
    07 tacoma prerunner
    After work on a 100 degree day I found my fan for the ac would only work on high, I went on the Tacoma World site and after reading several issues that everyone had from resistors to the motor and faulty wire harness connectors, I decided to try cleaning the female and male pins. This has worked so far thanks. The only cost to me was my time.
  2. Sep 1, 2015 at 7:46 PM
    Wrench1225
    Wrench1225 Well-Known Member
    jim
    NY
    SR5 4x4 db cab sb
    Rock sliders,total skids,toytec3" lift w adjustable UCA's and O ME,leaf spring pack, w toytec 2.5 rear shocks,diff.drop andBF Goodrich A/T 275 70 R16 (spare fits nicely under bed) Ultra machined Wheels, front camera. Seat covers,Bed liner spray(can't put a scratch in it) currently pricing diff.lockers with heavy duty pumpkin gears. Lastly winch w low profile bumper
    High speed is direct b+ from battery every other speed goes threw the resistor. The only other possibility would be the switch. The switch you remove from the electrical connector and jump the terminals the repair manual tells you to jump. If the fan operates when the switch is jumped then the switch is the culprit.
