AC not blowing after replacing resistor and blower motor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17tacomahtx, Apr 14, 2023.
  1. Apr 14, 2023 at 2:26 PM
    17tacomahtx
    17tacomahtx [OP] New Member
    TacomaOwner
    2017 Toyota Tacoma TRD Sport
    AC still not blowing after checking all the fuses, replacing the resistor and blower motor. What else could it be? Anyone have any ideas? Thanks!
  2. Apr 14, 2023 at 2:38 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Did you test the fuses for continuity, or just looked closely at them?
  3. Apr 14, 2023 at 2:49 PM
    17tacomahtx
    TacomaOwner
    Sorry, yes. Should have said that. Checked all the fuses and no issues.
  4. Apr 14, 2023 at 4:04 PM
    OnHartung'sRoad
    Power going to the blower? Dumb question, but another variable to test…. If not, then did you do any mods to the electrical system at all?
    These dumb trucks do wierd stuff , change something and something else logically unrelated to it stops working also.
    Chew and kahanabob like this.
  5. Apr 14, 2023 at 4:07 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Look at the connectors to see if any pins are burnt out. You can bench test a blower with battery cables.
    OnHartung'sRoad and kahanabob like this.
  6. Apr 14, 2023 at 4:57 PM
    Friend of Crows
    Friend of Crows Well-Known Member
    2022 Tacoma SR
    Painted steelies black
    Does the fan even power on? Or is it just not cold?
  7. Apr 14, 2023 at 5:54 PM
    17tacomahtx
    TacomaOwner
    The pins are all new. The blower motor all replaced with new wires and connectors. There is no power to the blower. Could the AC knob switch be bad?
  8. Apr 14, 2023 at 5:57 PM
    Friend of Crows
    2022 Tacoma SR
    Now we're getting into the nitty gritty, I'd need to see the schematic of where the wires from the blower motor get power from and find the next checkpoint so to speak. Can't imagine a switch would be bad but anything's possible. Did you recheck fuses after installing the new blower? Maybe it shorted after install?
  9. Apr 14, 2023 at 7:00 PM
    OnHartung'sRoad
    Hate to say this, but also check for rodent signs in your engine compartment…little shts chew on harnesses and stuff.
  10. Apr 21, 2023 at 8:46 AM
    Molina67
    Molina67 Well-Known Member
    Ken
    2022 Tacoma SR5
    Just found out why rodent like Toyota, apparently they use some type of soy bean when making wiring harness.
