AC Not staying cool
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gav1n8, Aug 19, 2019.
  1. Aug 20, 2019 at 3:37 PM
    Gav1n8
    Gav1n8 [OP] Member
    Trey
    2002 Tacoma 2.7 4x4 Manual
    System has never been opened. Does anyone know what the low high should be for specs?
    Thanks
    Insight likes this.
  2. Aug 20, 2019 at 8:34 PM
    Glamisman
    Glamisman Well-Known Member
    all of the pressures are ambient temperature sensitive... there are pressure / temperature charts for all the Freon types that are manufactured.
    A good baseline for R134a is with the compressor off and the system equalized the system pressure should be equal to the ambient temperature. 70 degrees outside, the H and L in the system should be approximately 70 psi.
  3. Aug 21, 2019 at 10:12 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    The high does look high and low does look low. I have a feeling you have a blockage/expansion valve issue.
    I replaced my entire system Condenser, receiver/drier, expansion valve, evaporator, compressor, all lines, and with my clutch fan at idle sitting still in 95+ degree weather my temp sadly stays around 55-60 and if on recirculating it can drop to 49-55. When moving it drops down to around 40. When the temp outside is around 70-80 the temp can drop below 32 though haha.
    I think it's the design of the system unfortunately. Not enough air past the condenser due to the clutch fan. If you switched to all electric fans with a relay to turn on when the AC is on you would see a good difference. I just cant justify spending $400 bucks on it and the hassle I hear from the electric fans if they fail.
  4. Aug 21, 2019 at 10:22 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Where do you live? I can certainly recommend a guy!
