AC Not Working 2015 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PilotBoy352, Sep 22, 2022.
  1. Sep 22, 2022 at 10:32 AM
    PilotBoy352
    PilotBoy352 [OP] Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    So I got in my truck today, and the AC wasn't kicking on. Air blows, and the AC and Internal Air lights are both lit up and not flashing. Any idea why?
    Last night, I did mess with my battery, I was installing a pair of KC lights and had the battery disconnected for maybe 2-3 hours since I had something come up in the middle of the install. Would that have anything to do with it?
    Thanks in advance. I live in AZ, so this is slightly critical so I don't broil alive.
  2. Sep 22, 2022 at 10:53 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you may have a leak, time to hook up service gauges, check pressures, and look for leaks.
    PzTank and PilotBoy352[OP] like this.
  3. Sep 22, 2022 at 10:55 AM
    PilotBoy352
    Tim
    Mesa, AZ
    Any tips on how to do that? I have no idea how the AC system works, and I don't have any of the tools or anything. Is it something I can do relatively easily myself, or should I take it into a shop?
  4. Sep 22, 2022 at 11:09 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It would be best to take it to a shop if you have no knowledge on A/C or tools.
    Since you say the compressor isn't coming on but the light isn't flashing that tells me the system is either out of refrigerant or the pressure switch has failed or the wiring to it is open.
    You may look in the area of the pressure switch (on the A/C line near the right headlight) and make sure you didn't damage the wires or leave it unplugged when you installed the lights.
  5. Sep 22, 2022 at 11:11 AM
    PilotBoy352
    Tim
    Mesa, AZ
    Will do. I'll take a look this afternoon once I get out of my classes. Thanks so much for the advice!
  6. Sep 22, 2022 at 11:38 AM
    ill ay
    ill ay I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    Keep us updated and best of luck!
  7. Sep 22, 2022 at 3:46 PM
    PilotBoy352
    Tim
    Mesa, AZ
    When I got back to my truck this afternoon to drive home, I figured I'd try it just to see if the AC would work. It did!
    I have no idea why it didn't work this morning, but it 100% was blowing hot air earlier. I don't know if there is a loose connection or something, but hopefully it is good from now on. I'll definitely be back for more help if it doesn't. Thanks for the help, it's great to have a place to ask my questions.
