AC not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AD Brown, Jul 19, 2019.
  1. Jul 19, 2019 at 2:11 PM
    AD Brown
    AD Brown [OP] New Member
    AD
    i have replaced the mgclt relay om my 2006 toyota tacoma and the ac light is still flashing
    None
  2. Jul 19, 2019 at 2:15 PM
    AD Brown
    AD
    None
    No how u do that explain so I can try it out
  3. Jul 19, 2019 at 2:16 PM
    AD Brown
    AD
    None
    I have pulled the relay and use a wire from battery to the wire that feeds the clutch, I could see the clutch turn
  4. Jul 19, 2019 at 2:30 PM
    AD Brown
    AD
    None
    You tube is saying if the indicator light is flashing to replace the relay that should correct the issue but still flashing
  5. Jul 19, 2019 at 9:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The clutch is probably shot. The blinking light means that the clutch was powered, but the compressor is not turning or is turning too slow with respect to the engine RPM.
    Turn it on and make sure that the center shaft of the compressor is turning along with the outer pulley when on. If it is it could be a slipping belt, but that usually makes noise and smoke. The pick up sensor mounted on the compressor could also be defective.
    Failure2Comply likes this.
  6. Jul 20, 2019 at 2:24 AM
    08RC
    08RC Well-Known Member
    The cure for the binking light on mine ended up being a bad AC amplifier. You may find there are many things that can cause that light to blink as I did after all the reading I did to get mine back up and running . I found the search tool and Google to be my best assistant for diagnostics
