AC only blows cold on drivers side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SlashGSX, Jul 28, 2022.
  1. Jul 28, 2022 at 12:23 PM
    SlashGSX
    SlashGSX [OP] Snow Monkey
    Brandon
    Lake Stevens
    MGM 18 TRD OR DCLB
    Custom mud flaps
    I’ve got a 2018 with about 35k on it and the AC seems to only work on the drivers side (I do not have dual climate control). The vent closest to the door is the coldest and it gets progressively warmer as we get to the passenger side.
    The first thought was the temp blend door actuator but I’m not convinced. I removed the glove box and I can see the actuator moving when I change from cold to hot and the temp changes accordingly. All of the doors that I can see move when they are supposed to (air direction and recirculate).
    It feels like I’m getting about the same air pressure out of every vent so I don’t think there’s a clog and I’ve seen no signs of rodent damage. The only issue seems to be that the air coming from the passenger vents is significantly warmer than the drivers side, but I wouldn’t call it hot.
    Could I have a stuck door that isn’t allowing cold air to flow to one side? And if so, how would I access that? Any and all advice is greatly appreciated!
  2. Jul 28, 2022 at 12:27 PM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Check your Freon level
    Greg-tacoma and SlashGSX[OP] like this.
  3. Jul 28, 2022 at 12:31 PM
    sajer
    sajer Member
    2006 black 4runner limited
    Possibly a leak , my old 4runner did the same thing.
    SH10151 likes this.
  4. Jul 28, 2022 at 12:31 PM
    SlashGSX
    Brandon
    Lake Stevens
    MGM 18 TRD OR DCLB
    Custom mud flaps
    Would that impact only one side? I’ll get it checked regardless but I guess that didn’t dawn on me
    OnHartung'sRoad likes this.
  5. Jul 28, 2022 at 12:35 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Yup. Common trait of the system being low. How it got low, however, is a different story.
  6. Jul 28, 2022 at 12:36 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    yes, very common
    I just went through this on my 2012
    my discharge line was leaking, only had cold air on the drivers left side vent
    installed new line, two cans of freon with dye, done...
    SlashGSX[QUOTED][OP] likes this.
  7. Jul 28, 2022 at 12:37 PM
    SlashGSX
    Brandon
    Lake Stevens
    MGM 18 TRD OR DCLB
    Custom mud flaps
    Awesome, thank you! I will ask my buddies with the right tools to help me check that!
  8. Jul 28, 2022 at 12:39 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    These trucks use a newer style refrigerant, not sure if you can find it in any cans.
    Otterstuff, RustyGreen and Skydvrr like this.
  9. Jul 28, 2022 at 6:34 PM
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    Let us know what the cause was....it will be my first mod. I am always too hot, my wife is always too cold. This "feature" would be perfect for me.
    Raylo, SlashGSX[OP] and RustyGreen like this.
  10. Jul 28, 2022 at 6:35 PM
    jandrews
    '09 FourDubDee TRD OR
    You sit on the driver's side. What's the problem?
    Raylo, Greg-tacoma and CaptainBart45 like this.
  11. Jul 28, 2022 at 7:14 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :amen:
    In the winter I'm in a shirt and dying :bananadead:, she is wearing a jacket with my jacket over her legs and packs a blanket for a longer trip.
    stftaco, Raylo, SlashGSX[OP] and 2 others like this.
  12. Jul 28, 2022 at 8:52 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    That's where I sit.
  13. Jul 30, 2022 at 10:48 AM
    SlashGSX
    Brandon
    Lake Stevens
    MGM 18 TRD OR DCLB
    Custom mud flaps
    I’m thinking about leaving it this way for that exact reason, except I take my dogs with me a lot and I don’t want them overheating.
    AxisCab likes this.
  14. Aug 9, 2022 at 4:11 PM
    SlashGSX
    Brandon
    Lake Stevens
    MGM 18 TRD OR DCLB
    Custom mud flaps
    Looks like my AC condenser is leaking so Toyota is going to replace it at no cost. Maybe I wasn’t a total idiot for getting that extended warranty! Would’ve cost me $1100 otherwise.
  15. Aug 9, 2022 at 4:17 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Let's think about this: Did you win because you saved $1,100, or did you lose because your wife will tell you over and over and over and over "I'm cold, turn down the a/c!"?
    Bob1971 and SlashGSX[QUOTED][OP] like this.
  16. Aug 9, 2022 at 4:20 PM
    SlashGSX
    Brandon
    Lake Stevens
    MGM 18 TRD OR DCLB
    Custom mud flaps
    She has sweatshirts. I still consider it a win
    stftaco likes this.
  17. Aug 9, 2022 at 6:25 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Don't even try with the over the counter refills on these trucks.
    They take 1234yf refrigerant only.
    You'll need it professionally serviced.
  18. Aug 9, 2022 at 7:01 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Not really, DIYed it myself with 1234yf cans, but I already had the right tools to do it, including a vacuum pump. It’s not as easy as just topping it off for a few bucks at Kragen anymore, that new stuff is expensive!
  19. Aug 9, 2022 at 7:05 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    I've done it as well with close help from someone who knew what they were doing and had a vacuum pump as well.
    Being that the original poster didn't know that they're low on refrigerant, I think it's safe to assume they're not ready to DIY this.
  20. Aug 9, 2022 at 8:11 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    stftaco and Phil61s like this.
