AC Only Works On High
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sarcastro, May 4, 2025.
  1. May 4, 2025 at 8:38 AM
    Sarcastro
    Sarcastro [OP] Well-Known Member
    Trevor
    2006 Tacoma TRD
    Can someone direct me to the repair walkthrough for fixing AC only working in high? I can't seem to find it through the search
  2. May 4, 2025 at 8:49 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. May 4, 2025 at 9:14 AM
    545 Well-Known Member
    2015 Access Cab
    Is this specifically the A/C only working on high, or is it the fan only works in the high position? Because if it’s the fan speed adjustment, then it is very likely your resistor.
    termaesam and ABA180 like this.
  4. May 4, 2025 at 9:27 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    What he said, though I surmise you mean the fan..please advise..
  5. May 4, 2025 at 12:01 PM
    Sarcastro
    Trevor
    2006 Tacoma TRD
    Dan only works on high for heat and AC
  6. May 4, 2025 at 2:30 PM
    Kocksan
    Kocksan Member
    Kirk
    2009 Tacoma TRD
    Had the same issue multiple times with my 2009. Probably changed the blower motor resistor 5 times. Finally found the best solution I've had so far.
    Fit perfectly and there seems to be no "looseness" between the male and female ends which I believe causes the unit to fail. Give this a try. I know there is a thread for how to change it, but just make sure you use this style of resistor. Good luck!
