AC or open windows for MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by savedone, Jul 17, 2013.
  1. Jul 17, 2013 at 7:52 PM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    Problem is you want to run the ac at low speeds and open the windows for higher. I'll be damned if I'm sweating at stop lights to get 10 more miles out of a tank.
  2. Jul 18, 2013 at 3:48 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I sit on a block of ice with my windows up. I get the best gas mileage that way.
  3. Jul 18, 2013 at 4:19 AM
    Deuxdiesel
    Deuxdiesel Well-Known Member
    SE MI
    '12 Silver Streak stocker
    This question came up on "Car Talk" a while back. Click and Clack gave the explanation that vehicles are so aerodynamically engineered now for better MPG's that windows down disrupts airflow, and leads to lower MPG. They suggested the window vent shade things as an experiment if you want to run windows down, but I don't recall any follow-up on that.
  4. Jul 19, 2013 at 6:20 AM
    savedone
    savedone [OP] Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Sometimes "Click and Clack" are quick and quack. Not every vehicle is aerodynamically engineered. Such claims are relevant not exact. One I have in mind is the Element, but there are several others and you can rest assured that trucks are not aerodynamically engineered like a car can be. So to suggest that windows down air off always uses more gas is simply incorrect. There are many variables that need to be considered and checked out for each driver and vehicle..
  5. Jul 19, 2013 at 7:20 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Windows up over 50 just cause its too noisy with them down.
  6. Jul 19, 2013 at 7:34 AM
    medic2230
    Murph
    Bama! Roll Tide
    I'm not taking a chance with mine. A/c on and both front windows down. FTW!
  7. Jul 20, 2013 at 4:06 AM
    blucoma
    blucoma Member
    Madison, NH
    '08 Tacoma double cab 4x4
    Plow
    This!!!!!!^^^^^
    Let's talk about comfort.
    90% of the time in my area [Mt. Washington valley, NH] there's no real need for A/C. Most summer mornings start in the 50's or 60's, and "average" hot days are low to mid 80's. You can wake needing a hoodie, and be in a wife beater by noon. Rarely, rarely humid, and most times always a breeze.
    This week however, it's been in the upper 90's, with ultra high humidity.
    Water in my lake is about 75 degrees.... :eek:
    I prefer to have 'em cranked down, and wind in my face, but this weather almost dictates A/C.
    Not worried about the mileage issue, as ya gots to do what ya gots to do.
  8. Jul 20, 2013 at 4:10 AM
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    12' reg cab 4x4 2.7L auto
    No windows down here, I just got my hair did up!
  9. Jul 20, 2013 at 4:39 AM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I usually end up with rear window open and one or both side windows open for short trips unless I have hauled mulch recently.
    Longer trips I do AC.
  10. Jul 20, 2013 at 2:17 PM
    jerzeyjoe
    jerzeyjoe Well-Known Member
    New Jersey
    08 Prerunner 2W
    Windows up, AC on!
    Keeps the dust out of my lungs.
  11. Jul 20, 2013 at 6:40 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    I sort of remember reading in Consumer Reports & Car and Driver, they always got better MPG with the A/C off, regardless if the windows were open or shut.
  12. Jul 21, 2013 at 4:07 AM
    blucoma
    blucoma Member
    Madison, NH
    Plow
    I'd have to have hair........:p
  13. Jul 21, 2013 at 7:54 AM
    Squirrellydw
    Squirrellydw Well-Known Member
    2012 PreRunner TRD Sport
    Your guess is as good as mine and that's all we ALL are doing is guessing. I believe MB was correct when they did that episode but it was only correct for that car. Every car is going to be different. Either way I don't think it will save that much.
  14. Jul 23, 2013 at 7:50 AM
    tacosteven
    tacosteven Member
    steven
    Del Rio
    13 PreRunner
    Having your windows down at 60 isn't going to drop your MPGs to 12 (if you are stock and getting 17). And as stated earlier, if you are worried about 20 miles from a tank, should you be driving a truck?
    For me, I drove a vehicle without AC for 7 years here in south Texas. I now drive with the windows down out of habit. I am used to it, and only use the AC when others are in the car or I am on the phone.
  15. Jul 24, 2013 at 3:47 AM
    #35
    blucoma
    blucoma Member
    Madison, NH
    Plow
    The day the heat wave broke up here I filled up, and reset the trip odo.
    I've gone 130 miles, and used a 1/4 tank.
    Doing the stupid simple math,
    20gal tank /4= 5gal per 1/4.
    130/5=26mpg with the windows up sometimes, A/C on, as tacosteven said, on the phone:
    but most of it driven both fronts open, lettin' the breeze blow thru my back hair......:eek:
  16. Jul 24, 2013 at 8:59 AM
    #36
    erockintaco
    erockintaco Well-Known Member
    ernie
    Italy
    05 Blk Tacoma Dc 4wd
    295 Ridge Grapplers. 2'10's subs.
    if your looking for better mpg's. I've always lived by windows down in the city. Windows up, ac on, on the highway.
  17. Jul 25, 2013 at 7:01 AM
    #37
    savedone
    Gerald
    Texas
    The problem is that doers not work. The gauge does not register exact usage at each mark, not even close. There is a lot of room for error. The only way to check it is to fill it up again and then do the math. By the way for the most accurate reading you have to use the same pump of the original fill, and at about the same time of day because of gas expansion from heat and you have to start with a tank that is topped off.
  18. Jul 26, 2013 at 4:05 AM
    #38
    blucoma
    blucoma Member
    Madison, NH
    Plow
    I'm on my fourth tank.
    One was pure highway, down to NJ.
    Mileage was 25mpg as opposed to my claimed 26. travelled at my normal 65-72mph. Never faster......really.
    Second was the trip back, load of furniture in the bed; 22mpg.
    Third was running round the roads up here, a mix of rural, town and some 55mph highway. That tank averaged about 20.
    I'm workin' the fourth, and came up with the figures I posted.
    Listen, I'm coming out of an Outback, that religiously got 26 town roads and 31-33 highway. I realized when I got the
    Tacoma I was also getting:
    A- 2 extra cylinders
    B- a vehicle less aerodynamic
    C- a truck!!!!
    20MPG on an average is alright by me for the twisty mountain roads and steeper passes.
    Overall, I am extremely pleased with the Tacoma's fuel efficiency, ride, and great looks.
    I guess what I'm sayin is I'm ok with the amount of fuel used, and if not, I'd have bought another gas sippin car.
  19. Jul 26, 2013 at 5:20 AM
    #39
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    I gain a solid 2-2.5 mpg with windows down I have the 4cyl. I do a lot of city driving and haven't tested it on the highway yet. At an idle when I turn the ac on I loose about 200rpms and I see that as a fuel/power loss.
  20. Nov 6, 2013 at 1:59 PM
    #40
    ironmanjay
    ironmanjay Well-Known Member
    True. They also did a show where they compared driving with tail gate down vs up and up won.
