AC outlet in the bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DdayIsNear, Jun 18, 2009.
  1. Jun 19, 2009 at 10:13 PM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    I used it for a rotary tool. worked fine with not problems. i also didn't have my engine running but the key was on the ON position.
  2. Jun 19, 2009 at 10:21 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Remember the term PIE.
    Power(P)=Current(I) x Voltage(E).
    Or if you have the power and voltage or current. P/IE
    So 400/120 volts = 3.33 amps.
    Look on whatever you are going to run off of the inverter. It should have a tag with a max amp rating. If the max amps exceeds 3.33 amps it won't run off of the inverter.
    At 100W you are looking at only being able to run .83 amps. Less than 1 amp at 100 watts.
  3. Jun 19, 2009 at 11:36 PM
    Taos1
    Taos1 Well-Known Member
    TRD Sport
    Access Roll Up Tonneau cover, Stainless Steel Sidestep bars, Pop&Lock, Grillcraft black Mesh Grill
    I only used it to charge my laptop while I was driving to my in-laws 10 miles away. I wish it wasn't there. Could use the extra storage space.
  4. Jun 20, 2009 at 8:35 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Huh? You wish the laptop wasn't there? Or does a covered outlet sunken into the side of the bed really take up soooo much space when you've got 2 giant wheel wells to contend with?
    Are we reading the same thread?
  5. May 6, 2014 at 10:11 PM
    RickyRocket
    RickyRocket New Member
    RICK
    05 TRD
    Has anyone tried using an engine stepper like on most emergency and military vehicles that use ac power onboard? it only steps up the engine 2 to 5 hundred rpm. Does anyone think that would make our ac outlet more useful?
  6. May 7, 2014 at 7:18 AM
    zmw
    zmw Well-Known Member
    SATX
    2014 TXproBAJA
    none
    Not without additional electronics. For those of you thst need higher current inverters just buy one and hardware it / the trd plug is for light and basic use. Drop lights small tools tcamping etc - it's not meant as a workplace power generator
  7. May 7, 2014 at 7:36 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    It definitely does not suck, not even in the least! Yes, it won't run a fridge or anything that pushes a lot of watts to make heat like a cook top or coffee maker, but if you stay within it's limits it's kick ass. I have used it for numerous awesome things. A box fan for one. When camping one time it was horrifically wet but with the use of a big box fan hooked to the outlet it was like a jet turbine and I was able to get a raging campfire going which is obviously essential for camp drunkenness. Also as said, a small air pump for a mattress and a drop light. I keep a drop light in the truck actually for roadside emergencies. And no one has mentioned christmas lights! It was all the rage in December but now the outlet sucks! LOL
    racerX969 likes this.
  8. May 7, 2014 at 7:54 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if you want real power there you'll need extra battery, and install a second alternator (there are kits but really messy in a tacoma) or replace the stock one with an HO alternator. and then change the circuit to allow higher watts
    much less hassle to just buy a little honda generator
  9. Jun 25, 2014 at 3:00 PM
    TMP1207
    TMP1207 What does this mean anyway?
    Eastern, NC
    '09 DCSB TRD
    Currently 2.5" ProComp Spacer Lift w/ TSB Leaf
    Will it run a small personal fan while driving? I can try to do the conversion but I don't think the fan has that info on it. I'm trying to cool a camper shell using the 5 gallon bucket AC trick...works we'll just don't wont to mess up the battery or alternator. I'm clueless when it comes to watts/amps, etc. thanks for the help!
  10. Jun 25, 2014 at 3:01 PM
    TMP1207
    Eastern, NC
    '09 DCSB TRD
    Would like to use it on short road trips to the beach...looking at running it for 2 hrs.
  11. Jun 25, 2014 at 6:17 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I've run a box fan with mine.
  12. Jun 25, 2014 at 6:56 PM
    DenverMojo
    DenverMojo Well-Known Member
    Evergreen, CO
    13 DCSB OR 6-spd
    can i run a trickle charger, to keep my battery charged, off of it? I would think the draw of the trickle charger would be within limits.
    :crazy:
  13. Jun 25, 2014 at 7:11 PM
    DonNH
    DonNH Well-Known Member
    Don
    Southern NH
    90 xcab>01dcsb>14dclb sport
    Better to go with a second battery in parallel and a higher output inverter. Then you could use a high amp charger/starter, so you could even start the truck up if your batteries were dead. :rolleyes:
  14. Jun 25, 2014 at 7:15 PM
    devkurf
    devkurf Member at Large
    midwest
    I would think a solar trickle charger would be a better bet. But you didn't state what battery you were trying to charge. Cell/Vehicle/Power Tools? That way you are'nt running one battery down to keep another one charged.
  15. Jun 25, 2014 at 7:20 PM
    #35
    DenverMojo
    Evergreen, CO
    13 DCSB OR 6-spd
    hah, was just trying to be a smartass...
  16. Jun 25, 2014 at 8:25 PM
    #36
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Runs my small air compressor.
  17. Jun 26, 2014 at 3:31 PM
    #37
    steep
    steep Member
    Mammoth
    2011 TRD OR
    I can't believe no one else uses it for their blender. Easily the best/booziest way to get your wife camping more when you can whip up a daiquiri or margarita on arrival. :D
  18. Jun 26, 2014 at 5:24 PM
    #38
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Solar chargers only produce DC, therefore you will not be able to charge anything other than a DC battery. You can't charge power tool batteries which require AC input.
    And, unfortunately, solar panels don't produce much wattage in an array that's usable in a Tacoma. You'd need a folding solar panel (unless you plan on mounting a big solar array on top of your truck). And the folding solar panels are very expensive. http://www.altestore.com/store/Foldable-Flexible-Solar-Panels/c542/
    Unfortunately, solar panels just do not provide enough wattage to be feasible for a mobile application in a truck. They can provide a very small trickle charge to a truck or trailer battery, but can't even keep up with discharge on said batteries. And, how do you mount them? A folding solar panel you have to mount it on a sheet of plywood, and when you're outdoors the wind will send that setup flying. Unfortunately, solar panels are just not feasible.
    A DC/AC inverter, with appropriate HO alternator and Big Three wiring upgrade, maybe (but not absolutely necessary) a second battery then you're in business.
    Or, a portable inverter generator. A generator can't be used when driving, but an inverter can be used.
  19. May 23, 2021 at 10:04 AM
    #39
    bonesamon
    bonesamon Member
    Craig
    2021 Tacoma Off Road 4x4 Silver
    Pro Grill, Aluminum Tri Fold Bed cover, Diode Dynamic LED Fogs, interior lighting LED
    Hi. Can someone tell me if the bed power, with engine running will power an electric chainsaw? It is 15 amps, cant find voltage? Anyone know if this will work? Thanks.
  20. May 23, 2021 at 10:40 AM
    #40
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    No it won't. Your chainsaw needs 15 amps, the bed outlet puts out 3.3 amps maximum. That AC outlet, as well as the AC outlets in your home are meant for an industry standard 120 volts. If your chainsaw required a different voltage then the plug would be different and you wouldn't be able to plug it into that type of outlet.
