AC outlet- who uses it
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZInferno, Nov 13, 2015.
Have you ever used the AC outlet in the bed of the Tacoma?
  1. Yes, I use it often
    26.2%
  2. I've used it once to see if it really works
    29.8%
  3. No, I have never used it
    44.0%
  1. Mar 5, 2016 at 12:05 PM
    #101
    StreetTiresJay
    StreetTiresJay Well-Known Member
    Jay
    British Columbia Canada
    '16 Taco TRD Sport DBLcab Alpine White 6M
    Wife in passenger seat, not driver seat :)
    Not sure if this question has been asked yet... But has anyone thought of a dual battery setup with wiring and a rocker switch to change between 12v parallel and 24v series?
    Would be complicated but if figured out by an electrician, you could swap the inverter with something else that could utilize the 24v when needed, or just use the extra capacity of the second battery when switched to 12v parallel
    I think Toyota's push button switch for the 3rd gen inverter is kind of dumb... Trying to think of a scenario in which I would need to limit the inverter to 100watts, or increase it to 400watts...
    I haven't used the inverter at all yet, maybe someone can clarify for me why Toyota did this?
  2. Mar 5, 2016 at 12:17 PM
    #102
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    2nd Gen owner here but it probably doesn't matter..
    Does the truck need to be turned on for this outlet to work? If I am driving I am guessing it is powered up and can work. What if I'm not driving? Do I just hit the button in the cab to activate it? Do I need to have the key in the ignition?
  3. Mar 6, 2016 at 5:53 AM
    #103
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Key in the ignition, lol....
    Truck must be running for it to give power. I think you can have it in accessory mode or driving for 100 watts. And it will give 400 watts when idling in park.
    They only 100 watts whole driving so all the other driving systems have enough power to operate.
  4. Mar 6, 2016 at 6:44 AM
    #104
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    400watts works out to something that draws 3.3amps @ 120V AC.
    its well above most run current, but well bellow start up.
    Not sure what you can use this for besides charging your phone or batteries for flashlights while camping. or maybe powering a little pump for blowing up an air mattress.
    Otherwise can't see really running any sort of tools. Basically anything with a motor will have too high of a start up current so wont work.
    unless its a macbook we're talking about. I know my charger is 400watt, and macbook batteries are 16.5V so can't connect directly to battery. You need to step up to 120V to then step down to 16V DC.
  5. Mar 6, 2016 at 6:55 AM
    #105
    Joe23
    I wonder how hard it would be to transfer the inverter over to a different battery.
    I'm thinking its a small inverter and limited to 400watt to reduce battery drain considering how much other stuff would be running off that same battery. But if you have a separate battery, and changed the inverter to a higher wattage one you could get more from it. Still not expecting to have enough power to run high draw power tools but still maybe double it up. Like 800watt. Be able to run a small coffee maker or something.
    Probably going to look into this once I get my taco finally. Shouldn't be too hard to do.
    Or like others said just putting in a bigger inverter. But I'd be too concerned with battery drain, especially considering when you'd be using this and causing that drain would possibly be out in the bush where there might not be anyone around to give you a boost.
  6. Mar 8, 2016 at 4:25 PM
    #106
    Z50king
    Eric
    Southern California
    Stock and loving it
    I think it's limited to 400 watts due to the size available to the inverter under the center console.
  7. Mar 8, 2016 at 5:02 PM
    #107
    WMDtech
    WMDtech Well-Known Member
    Nate
    TN
    2018 TRD OR 4X4, White, DCSB
    None... sigh
    Have not had the chance to use the one in the new Tacoma, but it was a life save in my 2014. I have a rental home in MO, was TDY and had use it to keep my batteries charged when working on the fence. I have tenant in the home so I really couldn't use their power.
  8. Sep 13, 2016 at 11:48 PM
    #108
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    What's a VCR?
    sdsurfer and Cows Have Claws like this.
  9. Sep 14, 2016 at 2:53 PM
    #109
    Cows Have Claws
    Cows Have Claws Well-Known Member
    Oregon
    2024 Tacoma Trailhunter 6ft
    The Magic Bullet blender only uses 250w... I'm thinking some camping truck bed margaritas might be in order. :) :cheers:
  10. Sep 14, 2016 at 3:30 PM
    #110
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    I've used it for a small blower. It works....
  11. Sep 15, 2016 at 10:49 AM
    #111
    RHelton10
    RHelton10 Well-Known Member
    Atlanta, GA
    '16 DCLB MGM TRD Sport 4x4
    Predator bars, Revolver X2 tonneau cover, SwingCase tool box, Husky mats, HID conversion Fuel vapor 17” wheels, 2” front /1” rear lift with Bilstein 5100’s, 285/70R17 Nitto grappler 2’s
  12. Sep 15, 2016 at 10:53 AM
    #112
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    I've used it a few times. The plastic cover is sharp as a knife and I've drawn blood twice flipping it up. Not sure if others have this issue, but I need to smooth mine out with a dremel.
  13. Sep 15, 2016 at 11:32 AM
    #113
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Reliability is just one consideration - the noise level is another - the Honda/Yamaha units are quiet, the cheap units are LOUD!!!
  14. Sep 19, 2016 at 8:55 PM
    #114
    Moondust
    Moondust New Member
    I will be taking a road trip soon and mostly staying at campgrounds. I have a small 1.5 qt slow cooker that draws 60 watts on the low setting. If I cook while I drive, is there any danger I'll be running down my battery? I would only run it with the engine on.
  15. Sep 19, 2016 at 9:10 PM
    #115
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Should not be a problem. Several folks do the same thing. I might try it someday.
  16. Sep 19, 2016 at 9:13 PM
    #116
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    This magnet thing is awesome!
    RHelton10[QUOTED] likes this.
  17. Sep 20, 2016 at 4:50 AM
    #117
    nortonian
    nortonian Well-Known Member
    I have one of these. I bought a kit from an outfit in Maine that also lets me run it on propane. Really convenient.
  18. Dec 5, 2016 at 2:22 PM
    #118
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Yep, I've adapted two eu2000i's to propane with a kit from http://www.motorsnorkel.com/
    The Maine outfit I believe is LP only, motorsnorkel.com is tri-fuel, you can still use gasoline if you like.
    LP has only 73% of the BTU's per gallon compared to gasoline but LP is so much easier to deal with.
    I bought a Yamaha 2000i already setup for tri-fuel from those motorsnorkel guys, it's running right now outside the trailer on LP, I doubt I'll ever use gasoline in it. Had to run it on gasoline for a three hour breakin period per the instructions, but that's it for me.
  19. Dec 5, 2016 at 2:29 PM
    #119
    monkeyface
    Colorado
    Oh, and for usage of the inverter, I had to run the trailer off of the 600W aftermarket in the Runner. The trailer battery bank failed and could not keep the furnace running overnight. I think the 400W could do the same, all it has to do is run the furnace fan and the piezo igniter, water pump, maybe an LED light. Very handy thing to have.
  20. Dec 6, 2016 at 3:52 AM
    #120
    nicxnac
    nicxnac Well-Known Member
    Nick
    Orange County, CA
    2016 Super White Tacoma Off-road 4x4 DCSB MT
    I use mine for Christmas lights!
    Sterling_vH111 and gpb like this.
