AC plug
Discussion in 'Technical Chat' started by EGtaco, May 11, 2009.
  1. May 11, 2009 at 3:25 PM
    EGtaco
    EGtaco [OP] Well-Known Member
    2009 Tacoma
    We the 400 watt inverter on the tacomas SUCK. It will not even power a coffee maker....Does anyone know where it is located and how difficult it is to change it to a more powerful plug. I was thinking of cranking the ampage and watts up to maybe 1000 watts. Has anyone done this?
    When I go camping and duck hunting I would love to have a fresh brewed cup of coffee in the morning and maybe watch a DVD before bed.
  2. May 11, 2009 at 4:18 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The actual inverter is housed in the bottom rear of your center console.
    You can swap out for a more powerful inverter unit, but I don't think most 'bigger' inverters will fit in the OEM console location.
  3. May 12, 2009 at 5:29 AM
    4x4Taco
    4x4Taco Well-Known Member
    Ontario
    07 TRD Off-Road 4X4
    Just remeber too that you will need all the wiring to be moslt likely upgraded to hold 80+ amps to get 1000watts.
  4. May 12, 2009 at 9:09 AM
    EGtaco
    2009 Tacoma
    yeah I figured I woul dhave to upgrade the wiring for a larger power supply.
    When you say center console do you mean the dash or the little console between the two front seats?
  5. May 12, 2009 at 9:34 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
