AC Prep Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by LarryJ, May 18, 2019.
  1. May 18, 2019 at 5:51 PM
    LarryJ
    LarryJ [OP] '97 Tacoma SR5, Auto, V6 - Virginia Beach
    Truck didn't have an AC compressor in it when I bought it a few months ago. Besides installing a compressor and refrigerant, what prep should I do. I have no idea how long it hasn't worked. I have never worked on AC units before except adding refrigerant. Thanks.
    GQ7227 and PennSilverTaco like this.
  2. May 18, 2019 at 5:54 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    You’ll have to pull a vacuum for quite some time once you get the compressor installed. Make sure the systems tight & you should have no problems.
  3. May 18, 2019 at 5:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Compressor and refridgerant is easy.
    The condensor with fan/wiring relay is hard.
    The evaporator in the heater core is an absolute bastard.
    GQ7227 and CS_AR like this.
  4. May 18, 2019 at 7:04 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    An SR5 that didn’t come from the factory with A/C?!?!
    GQ7227 likes this.
  5. May 18, 2019 at 7:05 PM
    95v6mt
    95v6mt Well-Known Member
    scott
    maryland
    95 v6 mt extra cab
    Make sure you put in a new receiver dryer. Esp if its been open to the air for a long time.
    Assuming our truck have one.
    CS_AR and Bend_corners like this.
  6. May 19, 2019 at 1:27 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Ok if the AC lines were capped off you might get lucky !!
    If the system has been open to the Air this could be a very long and expensive adventure of replacing one part after another.
    As creepy crawling and flying insects just love exploring such places .
    Most Shops doing this most likely would quote to replace everything .
    CS_AR likes this.
  7. May 19, 2019 at 5:39 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    OP said it was missing just compressor :confused:
  8. May 29, 2019 at 4:07 PM
    LarryJ
    Hey, thanks for all the replies. I misspoke. The truck has an a/c compressor. The previous owner said it needed one, so I assumed it had been removed and didn't bother looking until after posting. The a/c makes an awful squealing noise when its turned on. Didn't some research and learned that later model 1st gens have idler pully issues that create a loud squeal when the bearings go. Hoping that's my problem.
    cruiserguy likes this.
