Ac problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steve4x4tacoma, Jul 28, 2019.
  1. Jul 28, 2019 at 2:06 PM
    Steve4x4tacoma
    Steve4x4tacoma [OP] Member
    2012 Trd Tacoma
    ac freezing when on highway but when I come to a stop the ac starts getting warmer!! Any ideas?
  2. Jul 28, 2019 at 2:11 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  3. Jul 28, 2019 at 3:55 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    See if your condenser needs cleaning. It's in front of your radiator.
  4. Jul 28, 2019 at 4:03 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    A lot of 2nd Gen Tacoma's are fine on the road and not so fine in stop-n-go traffic, especially if your truck has been parked in the sun and you start out going from red light to red light. Doesn't get cold until you really get on the road and get some wind going consistently through the condenser.
    As stated above, condenser fan would likely help.
  5. Jul 28, 2019 at 7:21 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    In addition to more heat exchange at the condenser, the higher speed of the engine means higher rpms of the compressor. Its able to move a larger volume of refrigerant and therefore remove more heat from the cabin
    FishingPups and Lester Lugnut like this.
  6. Jul 29, 2019 at 4:48 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Pusher fan!!!
  7. Jul 29, 2019 at 5:40 PM
    Steve4x4tacoma
    2012 Trd Tacoma
    I put a new condenser in... today I was gonna change the fan clutch but I don’t think that the problem! Could the fins in the radiator being clogged cause this also. There was a crap time of weeds in the radiator, washed them out but do I think I made need to change the radiator with a new one?
  8. Jul 29, 2019 at 5:44 PM
    Lester Lugnut
    How well did you clean the radiator? - both front and back? I'm assuming a vacuum was pulled and the system was properly charged after the new condenser..
  9. Jul 29, 2019 at 5:51 PM
    Steve4x4tacoma
    2012 Trd Tacoma
    Yes to all of those!
  10. Jul 29, 2019 at 5:52 PM
    Steve4x4tacoma
    2012 Trd Tacoma
    In the mornings at idle the ac is freezing. Seems when the temp outside is 70 or above just doesn’t wanna cool at idle.
  11. Jul 29, 2019 at 5:53 PM
    Lester Lugnut
    are you still cooling on the highway, but not in stop-n-go?
  12. Jul 29, 2019 at 5:56 PM
    Steve4x4tacoma
    2012 Trd Tacoma
    Yes so cold I have to turn it down.
  13. Jul 29, 2019 at 5:58 PM
    Lester Lugnut
    You must live in a cooler climate. I rarely have to turn mine down on the hwy in the summer.
    Might be time for that fan mentioned above.
    Steve4x4tacoma[OP] likes this.
  14. Jul 29, 2019 at 5:58 PM
    Steve4x4tacoma
    2012 Trd Tacoma
    Once I start going it seems to cool better. The longer I sit, starts to get warmer and warmer.
    Lester Lugnut likes this.
  15. Jul 29, 2019 at 6:15 PM
    Lester Lugnut
    Many 2nd Gen 4.0L owners have that problem. That's why the fans have been suggested.
