AC Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Andy2675, May 5, 2020.
  1. May 5, 2020 at 4:12 PM
    Andy2675
    Andy2675 [OP] Active Member
    Andrew
    2011 Double Cab 4x4 Manual
    So just yesterday I noticed that it was taking my truck a LONG time to cool off after sitting in 80+ degree weather while at work. I noticed that the air moving from driver to passenger was getting warmer at each vent until the far passenger one was basically the air temp outside. It also seemed like there was a hissing/blowing sound in my far driver side(the one still cold) that sounded like there was a straw deep in the vent having air pushed through it. So I searched through the forums here and checked the blend door. It still moves and operates as should so I am suspecting it to be a freon leak somewhere. Is there a more common place that it leaks and is it something that can be seen visually? I will definitely have to bring it somewhere because I have never touched A/C before and would most definitely f*** something up if I did it. I would just like to say the definite problem before I bring it in somewhere and have them try to run me through the ringer. TIA
    :toyota:
  2. May 5, 2020 at 4:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That’s a classic sign of Low Refrigerant in these trucks.
    That would be my guess. Low Refrigerant.
    Andy2675[QUOTED][OP] likes this.
  3. May 5, 2020 at 4:57 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I had the same issue last yr. It ended up being a small leak in the condenser. You could get lucky and it could be just a o ring.
  4. May 5, 2020 at 8:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Agree with the above I had the same issue a few years back... Fix the leak evacuate and recharge the system.
