AC runs with it turned off
Discussion in '4th Gen. Tacomas (2024+)' started by Johnthearcher, Jul 3, 2024.
  1. Jul 3, 2024 at 12:24 PM
    Johnthearcher
    Johnthearcher [OP] Active Member
    john
    2024 SR5
    Just like the title reads, I notice the vents blowing ice cold air with the AC off. I do not use the auto feature either. Anyone else notice this? Funny thing is I found the same issue with my Wife's 23 Rogue from Nissan. In both cases I am certain of what I am experiencing. Nissan admittedly said they all work that way. Crappy thing is you need to turn it on then off again to shut the compressor. Have to play around with the Tacoma but I am certain the AC comp is running with no AC button depressed on the dash with inside or outside air selected. Would love to know if anyone is seeing this too with their 24 Tacoma. Most people would probably never even notice this.
    GoldenJoe likes this.
  2. Jul 3, 2024 at 12:32 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    There’s another thread on this issue. You aren’t alone.
    shakerhood likes this.
  3. Jul 3, 2024 at 12:57 PM
    Plank Owner
    Plank Owner Active Member
    2024 TRD Sport 2wd
    There is a setting where this can be disabled. It works for some and not for others, seems like it is glitchy software. I suggest reading through this thread:
    https://www.tacomaworld.com/threads/how-is-the-ac-in-the-2024.831315/unread
  4. Jul 3, 2024 at 1:10 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    It is a feature.
    3r3Taco likes this.
  5. Jul 3, 2024 at 2:10 PM
    CrispyTacoLover
    AC on 24/7 365 is perfectly fine in the south. :D
    drizzoh and Lionsgaffer like this.
  6. Jul 3, 2024 at 4:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, others have seen it.
    Not all peoples trucks seem to do it.
    And it has been confirmed with at least 3 different trucks side by side, not all do it with the same settings.
    Either the people that know why it does it, aren't saying.
    Or no one on this forum knows why. (I'm one of them).
    shakerhood and CrispyTacoLover like this.
  7. Jul 3, 2024 at 4:34 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    I have had cars and trucks that engaged the AC when the selector controls were set to defrost or windshield/dash vents and the temps were above 40 degrees. My current 2014 Toyota does this. Purpose is to de-humidify the incoming air to help keep the windshield and other windows clear. No buttons pushed, no lighted indicator, but you can feel and hear the compressor kicking on and off. Probably not this issue here, but just throwing it out there. Every car I have had with automatic climate control did this, but you could always over-ride it if you selected manual control or on more recent models with separate a/c button: defeat/turn it off. It would still be in automatic climate control mode: but without the a/c compressor in the loop to help.
    The a/c on/off (button) option came later allowing you to manually turn off the compressor while still allowing automatic system control of everything else. (vent/air outlets, temperature and fan speed) Selecting defrost or defog always turns on the a/c compressor. No over-ride to manually turn it off this feature, but it is automatically defeated below temps of 40 degrees or so.
  8. Jul 3, 2024 at 4:38 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Toyota probably equipped the 4th gen with an interior humidity sensor which will engage the AC for humidity, not just temp.
    My Chrysler 300C has this and yes it’s annoying.
    Williston likes this.
  9. Jul 3, 2024 at 4:44 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Turn on recirculate mode and it stops airflow from spinning the blower motor
  10. Jul 3, 2024 at 4:56 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Mine did this when I first got it. If you cycle the AC button it will stop.
    Now my truck doesn’t do it. It learned I guess
    PDKTaco and stinkyyamalinky like this.
  11. Jul 4, 2024 at 1:14 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Pretty sure my 2019 did this, and I’m 99p certain my 2014 does this when I run the defrost setting without the AC engaged.
  12. Jul 5, 2024 at 10:09 AM
    Johnthearcher
    john
    2024 SR5
    Seems that when I shut truck off without turning off the ac the next time I start it up it goes to ac mode with no light lit on AC button on dash. I will read the link to the other thread posted above. Thanks.
  13. Jul 5, 2024 at 11:50 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    "If the fan speed setting or air
    flow modes are operated, the
    automatic mode indicator goes
    off. However, automatic mode
    for functions other than that
    operated is maintained."
    Not sure if i'm reading this right but it seems if you use Auto, and change the fan speed not actually hitting the off button, the other things controlled are still in auto mode.
    I just know I rarely have to turn on the A/C button, I just set my temp and it usually cools.
    SR-71A likes this.
  14. Jul 6, 2024 at 3:04 PM
    Johnthearcher
    john
    2024 SR5
    No I do not use the auto mode ever. I use fan manually and toggle the ac on or off as needed. Like I wrote above if I shut the ac then the fan then shut truck The system works like expected the next time I start the truck. There is no setting on my truck like the one that is referenced above in Plank Owners post.
  15. Jul 24, 2024 at 1:52 PM
    Williston
    New England
    Re: >>>It's a feature<<<
    Maybe so: albeit one that will significantly reduce the overall useful lifetime of the $$$$/expensive compressor which is always in: "run all of the time" mode.
  16. Jul 24, 2024 at 2:54 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    My 2023 Tundra does this. AC indicator in readout has "On", Off" or not lit up. I notice the compressor and cold air in either ""On" or "not lit up" modes. Cycling the button so that "Off" is indicated solves the problem and it does remain off even if the truck is shut down and restarted.
    Not sure if your Taco has a similar setup but since a lot of your controls appear to be similar to the Tundra I thought I'd throw that out there.
    And... my 2021 Altima with manual AC controls does this as well. "Feature not a bug "????
  17. Jul 24, 2024 at 3:57 PM
    drlmrls
    drlmrls Member
    2024 Bronze Oxide TRD Sport
    I thought I was the only one here but noticed mine was blowing cold air even with the AC button off.
  18. Jul 24, 2024 at 3:59 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Another thing I try and do is turn off my AC before I shut off the engine. No issues reported
  19. Jul 24, 2024 at 4:14 PM
    CrispyTacoLover
    I try to run mine 365 days a year.
  20. Jul 24, 2024 at 4:20 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Toyota taking cues from Microsoft...
