AC smells like old socks / cat piss
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wdavis18, Aug 21, 2017.
  1. Aug 21, 2017 at 7:36 PM
    wdavis18
    wdavis18 [OP] Active Member
    2014 Black TRD Sport Tacoma (4.0L v6)
    4inch suspension lift, 2inch blocks, 33x12.5xR20 mud tires, front steel bumper
    My AC smells like cat piss when running from inside and through the fans. Anyone know solutions/problem of this?
  2. Aug 21, 2017 at 7:37 PM
    nocturne
    nocturne Well-Known Member
    Erin
    San Antonio NM
    2015 TRD Off-Road
    Bone stock
    Changed the air filter recently?
    BillsSR5 likes this.
  3. Aug 21, 2017 at 7:38 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    cabin filter
  4. Aug 21, 2017 at 8:08 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    A cat really did piss in your A/C
    Avsfreak18, Stemmy and irayfz6 like this.
  5. Aug 21, 2017 at 8:43 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    Mouse found a new home? Maybe start looking around for some mouse turds as well.
  6. Aug 21, 2017 at 8:59 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Evaporator core is leaking. Freon smells really bad.
  7. Aug 21, 2017 at 10:14 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Mully likes this.
  8. Aug 22, 2017 at 3:09 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Make sure your drain line is clear.
  9. Aug 22, 2017 at 3:23 AM
    JCruiser
    JCruiser Well-Known Member
    Master Chief (E-9) USN (Ret)
    Georgia
    '23 Tacoma SR5 4WD 4D "Ice Cap" w/ XP Package
    Upcoming...... Pro grille and driving lights
    I had something similar. What I found was that there was spanish moss that had collected on the cowling (just below windshield). After a week it has broken down into smaller particles. I washed my truck. Smell was still there. I changed the cabin air filter (found behind the glove box) and the smell was still there, but not as bad. One of the techs at my local dealer said to spray lysol (not fabrese) on the filter and run the a/c for a few days only on outside air (not recirculate). If a little helps a little, a lot should help a lot, right? So I sprayed some lysol around the outside air intake, inside the cab and checked the drain line.... come to find out that the drain line was partially clogged by a mud-dabber bee. A coat hanger took care of the mud and I was able to get it up in there far enough.
    The next day NO smell was visible and my truck did not smell like lysol, probably because I rode with the windows down. Another thing the tech told me was that if it was really hot outside, before I cut the truck off, to turn off the "recirculate" switch a minute or so early. This keeps the stale air from collecting in the cabin, and if you have a dark colored truck will allow at least some of the heat to escape.
    Where I live, some of the older cars have had their back glass blown out because of the heat...or at least that is what has been suspected. Good luck.
  10. Aug 22, 2017 at 6:36 AM
    wdavis18
    Ya i was out of town for a month and had to leave my truck in the driveway, so it might have collected some rotting leaves under the hood. I cleaned them out but the smell is still there. Might check the filter and what JCruiser said.
  11. Aug 22, 2017 at 7:04 AM
    el_smurfo
    el_smurfo Well-Known Member
    Both my wife's mini and my Tacoma get this. At the dealership, they just remove the filter and spray Lysol into the cabin intake while the system is running to kill mildew in the system, so that's what I do and it works well.
  12. Aug 22, 2017 at 8:16 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  13. Mar 19, 2023 at 10:03 AM
    wdavis18
    Update: had a small unwanted critter (lizard or something) that made its way onto my ac filter fan and had died. I had left my truck for a few weeks while I was on a trip. If anyone has a similar smell always check the filter behind the glove box!
