AC still not working. any ideas.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Jul 5, 2011.
  1. Jul 5, 2011 at 5:17 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    so when I bought my truck (used) the AC didn't work. The compressor was bad. That was replaced and the AC worked. About a week later it quit blowing cold. so i took it back and they recharged the system. It blew ice cold for 3 days and now it's not working right again. As of right now, it's only blowing cold out of the drivers side vent. Any ideas what it could be. I suspect it has a leak somewhere. I was gonna take it in next week and see what they say, but wondered if there was something I could do in the mean time.
  2. Jul 5, 2011 at 5:26 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    sounds like maybe the refrigerant is leaking?
  3. Jul 5, 2011 at 5:28 PM
    adamv22
    adamv22 Well-Known Member
    adam
    29 Palms, California
    06 tacoma Sport
    6" Rough Country lift, Toyota roof rack, Tepui RTT, Hidden 12000lb winch Pioneer 6.1 DVD stereo, Cobra III CB radio,
    does the AC light come on when you push the button?
  4. Jul 5, 2011 at 5:45 PM
    TacomaPrime
    Gregory
    Illinois
    yes it does. And stays on. when the compressor was not working, it would come on then the compressor was making a horrible noise, and the ac light would start blinking.
  5. Jul 5, 2011 at 5:51 PM
    TacomaPrime
    Gregory
    Illinois
    thats kind of what I am leaning towards. I think I am gonna take it to my own mechanic and pay to have it fixed. the shop that tried to fix it before apparently can't do it.
  6. Jul 5, 2011 at 6:17 PM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Sounds like they need to evacuate it and then put a vacuum on it and see if it holds. I'm guessing it won't. My first 05 and my brother in law's 05 both had the A/C compressors die when they were about 4 years old. My current truck (also an 05) had the compressor replaced once already. When I redid the A/C in my old fox mustang last year I brought it to 1 shop that didn't have a clue and talked to a few others who were also clueless. I wound up buying my own A/C gauges and vacuum pump and did all my own testing and charging. Still blows 38 degrees a year later.
  7. Jul 5, 2011 at 7:31 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    It's blowing cold out of one vent, so you have cooling. That's not a refrigerant leak problem, because there isn't a way for low refrigerant to only affect one vent.
    If the driver's side vent is blowing, but the others aren't, that's a problem with the dampers or their controls.
  8. Jul 6, 2011 at 4:39 AM
    TacomaPrime
    Gregory
    Illinois
    It did that last time too though. At first it just blew cold air out of the drivers vent, then after a day or two, it stopped blowing cold at all.
  9. Jul 6, 2011 at 5:57 AM
    TacomaPrime
    Gregory
    Illinois
    Negative Ghost rider.
  10. Jul 6, 2011 at 6:00 AM
    TacomaPrime
    Gregory
    Illinois
    This morning it's not blowing cold at all again out of any of the vents. Time to take it to a professional.
  11. Jul 6, 2011 at 7:19 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    99% sure you have a leak in the system as some have suggested. Go to a qualified A/C shop and they will fix it. :cool:
  12. Jul 15, 2011 at 1:01 PM
    TacomaPrime
    Gregory
    Illinois
    Hmmm. Well, it seems to be puzzling me. The drivers vents blow out super cold air, but the middle passenger one is only mildly cold, and the passenger one is barely cold, if at all.
    I never sit in the passenger seat, so I dont know if it's supposed to be that way or not. It should be blowing out the same temp air out of all the vents, right?
  13. Jul 16, 2011 at 12:06 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    You have some servomotors that control the air movement.
  14. Jul 16, 2011 at 12:33 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    If its blowing out cold in one I would bet the air mix servo's aren't working correctly. If you switch to heat does it come out the same temp in all the vents? Also have you tried switching to vent/floor mix? The servo might just be stuck a little, try moving the temp to hot>cold>hot a few times to possibly unstick it.
  15. Jul 16, 2011 at 12:44 AM
    ACE808
    ACE808 Well-Known Member
    DDS
    808 State
    TRD Off Road 4x4
    Toytec 3" lift light racing uca moto metals 17" (958) k&n intake Helix throttle body Borla exhaust Nfab step bar All-pro transfer case shield All-pro spindle gussets All-pro sway bar links All-pro E-locker guard All-pro rear differential armor All-pro U-bolt flip kit L.E.D. White/Blue Dash Gauge lighting Full alpine stereo with TV screens Clifford alarm optima red top battery Full wet okole seats auto meter gauges (oil pressure & volt meter) Ebc slotted & dimpled rotor Goodrich braided brake lines Hawks Lts brake pads Rear diff breather relocation
    It's an air flow problem. Check to see if a damper is not closing or opening. Try to switch the vent settings. But to be sure I would check the pressures anyway. Remember now it's R-134a type freon. Check the pressures while it's cycling.
  16. Jul 16, 2011 at 4:10 PM
    TacomaPrime
    Gregory
    Illinois
    Well, I still think it's a leak. because now it doesn't blow cold at all AGAIN.
    when I first get it back, it blows cold out of all the vents, then eventually only out of the drivers side, now not at all. the guy always says the freon is low when I bring it back. the heat blows super hot out of all the vents, and the fan blows the same temp out of all of them. And like I said, now it isn't blowing out cold at all. I would guess there is still a leak and the freon is low again. Where are the most common places for leaks. He replaced the O rings on the compressor last time.
    Im trying to figure out how long to let the dealer's guy fix it for free, until i just say fuck it and take it either to my guy or the dealer.
  17. Jul 16, 2011 at 4:15 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    If you go to an A/C shop, they're going to put UV dye in your refrigerant which turns into a horrible mess, then they're going to charge you a ridiculous amount of money for doing little to no work at all.
    Go to home depot and buy a bottle of gas leak reactant soap bubbles. Then go to autozone and rent a set of gauges and buy a can of R-134a. Charge it per the instructions and spray it on all of the joints you can see with the soap bubbles. You should be able to locate the leak in less than 5 minutes, if you have one.
    BAM, fixed for <$50
  18. Jul 16, 2011 at 4:17 PM
    ACE808
    DDS
    808 State
    TRD Off Road 4x4
    U can use a dye to trace a leak. Or look for oil stains around the refrigerant piping. Leaks can pop out of anywhere
  19. Jul 16, 2011 at 4:18 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Dye is horrible. Soap bubbles are cheaper, easier, and safer for the system.
  20. Jul 16, 2011 at 4:47 PM
    TacomaPrime
    Gregory
    Illinois
    ugh. I've never done anything AC related.
