AC stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by headmedguy, May 17, 2020.
  1. May 18, 2020 at 7:18 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Do what now?! What blew compressed coolant?
    And... you 'topped it off' with no blower running? :eek:
    Jimmyh and wilcam47 like this.
  2. May 20, 2020 at 7:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    o_O
  3. May 20, 2020 at 2:29 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Bad move you cannot just add refrigerant it can not be done properly without a gauge set and knowing what the outside temp is and again it has nothing to do with the blower running if it's low the compressor will not turn but the blower will run. You will need someone with a gauge set to properly charge the system now or you will have even bigger issues.
  4. Jun 23, 2020 at 5:43 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I wanted to share. I had the exact opposite problem as everyone else. After searching for a while I thought this thread might be the right place to put my experience. My '12 taco was not running when on high but worked in the other settings. I checked all the connections down by the blower and they looked good. My connection at the back of hvac panel was not good. I cleaned it up with some fine grit paper and alcohol. Dabbed a little dielectric grease and now it's good. Not sure for how long and don't know why it happened but fingers crossed. Hopefully if someone else has an issue like mine, this will help. 20200623_170945.jpg 20200623_170945.jpg 20200623_170931.jpg
    wilcam47 likes this.
  5. Jun 23, 2020 at 7:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Why the dielectric grease?
    Dielectric grease is a non conductor.
    Another option is a slight bend in the male pin or a thin coat of solder to tighten up the connection.
    What causes the burning is a loose connection between the male and female terminals acting like a heater. Unless corrected the problem will return.
  6. Jun 24, 2020 at 12:05 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    I thought so too. Loose connection would cause more resistance which would cause more heat, correct? I did bend it slightly but thin coat of solder is a good idea, thanks.
  7. Jun 24, 2020 at 12:07 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Did you check the fuses?
  8. Jun 24, 2020 at 12:13 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    If the question was for me, no. Because it was working on all other settings I didn't check the fuses. I figured they wouldn't separate each setting and put them on separate fuses. It is working now but I think I will be following jimmyh suggestion of tightening the connection with a small amount of solder. I should have checked tho
  9. Jun 24, 2020 at 12:14 PM
    PennSilverTaco
    Charlie
    jimmuh always seems to have really good suggestions...
    Jimmyh likes this.
  10. Jun 24, 2020 at 7:12 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes loose connection is resistance to current flow and Decipitates energy causing heat.
    In simple terms it becomes a heating element.
