AC stops working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by henrilepuf, Mar 5, 2018.
  1. Mar 5, 2018 at 7:09 AM
    henrilepuf
    henrilepuf [OP] Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    Hello
    Another issue that never happened with my old TRD 2008 :
    when driving my TRD 2014 in water or liquid mud, AC stops operating.
    Is there any security sensor working?
    Or have I any electrical/electronical issue ?
    Thanks for helping
  2. Mar 5, 2018 at 7:12 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Can you elaborate? The AC light turns off or the AC just stops pumping cold air?
  3. Mar 5, 2018 at 7:54 AM
    henrilepuf
    henri
    The AC stops giving cold air, and the A/C light is flashing (on the little switch)
    When out of the mud, I put in position OFF, and than again ON, and it works instantly.
    Hope it will help if you've an idea...
  4. Mar 5, 2018 at 3:37 PM
    henrilepuf
    henri
    No 2014 owner experienced that ?
  5. Mar 6, 2018 at 2:44 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    When the AC Light Flashes it means that the speed sensor at the AC Clutch detected that the pulley was not turning or not turning at the proper speed.
    More than likely the cause is the belt is wet and slipped which causes the fault. Usually cycling power via the AC Button will reset the fault and all is well again. It may help with a new serpentine belt. I have heard good things about the Goodyear Gator Back Belts.
    https://www.autobarn.net/goodyear-belts.html
  6. Mar 6, 2018 at 3:08 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Stop driving through water or liquid mud then.
  7. Mar 6, 2018 at 8:04 AM
    henrilepuf
    henri
    Thanks a lot for your help.
    It seems the best explication.
    Do you thnink Goodyear serpentine belt is better than Toyota belt ?
    Mine has 18k miles, it's quite new .....
  8. Mar 6, 2018 at 8:06 AM
    henrilepuf
    henri
    Okay.
    But for me, it means 'stop working'.....
  9. Mar 6, 2018 at 11:01 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I'm wondering, is it possible to tighten up on the belt a little bit?
  10. Mar 6, 2018 at 3:15 PM
    henrilepuf
    henri
    I
    I think the belt tensioner does the work and there no way to tighten up the belt...
    Unless I'm mistaken......
    wilcam47 likes this.
  11. Mar 7, 2018 at 7:21 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Maybe.
  12. Mar 8, 2018 at 7:55 AM
    henrilepuf
    henri
    There's no Gatorback Goodyear serpentine belt for our 4.0 V6 engine.
    Other brands are : Continental, Bando, Gates ....
    Any opinion about which is better (thinking in water and mud...)??
  13. Mar 8, 2018 at 1:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  14. Mar 8, 2018 at 1:43 PM
    henrilepuf
    henri
    Yep, I missed that in that link ...
    So, it's Continental.
    Thank you Sir
  15. Mar 8, 2018 at 1:47 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  16. Mar 9, 2018 at 4:28 PM
    henrilepuf
    henri
  17. Mar 9, 2018 at 4:31 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I havent paid attention to this but does vehicles with V-belts have tensioners? I know the serpentine belts have tensioners, the old school v-belts you adjusted the tension but I dont know about the newer stuff post 86...
  18. Mar 9, 2018 at 4:42 PM
    henrilepuf
    henri
    In our 4.0 V6, I think the tensioner does the job. (and I believe it's a good job)
    No way to adjust tension.
    wilcam47[QUOTED] likes this.
  19. Mar 9, 2018 at 9:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes, the "old school" V Belts had tension adjustments. The modern serpentine belts all use a preset tension pulley as far as I know.
