AC Ticking Time Bomb
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kiloyard, Aug 24, 2025.
  1. Aug 24, 2025 at 6:47 PM
    Kiloyard
    Kiloyard [OP] Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I've had this noise for a few years now. It's a sort of an irregular loud ticking from the front of the engine. It's not louder on any particular side, that I can tell. It's loudest during idle, and does speed up and quiet down with higher revs. I just discovered today it only occurs while the AC compressor is on, so it must be ready to go.
    https://youtube.com/shorts/RoYq2ZuwGEM (0:43 above engine)
    https://youtube.com/shorts/z3vIA6KBzNU (0:16 below engine)
    Sounds like a bearing noise to me, though it could be something like a failing harmonic balancer. First video shows no visible wobble in the crank pulley, though. Any wild guesses?
  2. Aug 24, 2025 at 7:47 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Man, if bearing would be more consistent hum/squeal
    that is more of a intermediate ticking
    my internet guess is T belt tensioner
    can u narrow down more exact area of the tick?
    Like with
    -long screw driver with your ear to the handle
    Or
    -mechanic stethoscope
    Kiloyard[OP] likes this.
  3. Aug 24, 2025 at 7:55 PM
    Kiloyard
    Phoenix, AZ
    I did put in a new timing belt, tensioner and idler pulleys about 5 years ago, possible I screwed something up then. But then I wonder why it only ticks while the AC is on. If I switch it off, the sound immediately stops. I switch the AC on and it comes back 1-2 seconds after. I might try adjusting belt tension and see if that helps.
  4. Aug 24, 2025 at 7:59 PM
    ControlCar
    Steven
    Sugar Land TX
    Hmmmm
    AC clutch possibly
    Can u do that screwdriver/stethoscope method to confirm that tick coming from AC compressor/clutch pulley?
  5. Aug 24, 2025 at 9:30 PM
    Kiloyard
    Phoenix, AZ
    Ah, I will try that when I get back into town. Thanks for the idea!
  6. Aug 24, 2025 at 9:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I wouldn't be surprised if the compressor was making noise, it's over 25 years old
