AC trouble, compressor not engaging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Electrician, Jun 26, 2023.
  1. Jun 26, 2023 at 4:33 AM
    Electrician
    Electrician [OP] New Member
    2015 Tacoma tad 4/4
    Filter was clogged, replaced. Must have blown fuse between a/c and heating. Any ideas
  2. Jun 26, 2023 at 4:47 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    By filter you mean cabin air filter?
    Does the blower work?
    A/C light comes on?
  3. Jun 26, 2023 at 4:49 AM
    Electrician
    2015 Tacoma tad 4/4
    Yes, cabin air, ac light comes on steady no blinking.
  4. Jun 26, 2023 at 4:50 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So your blowing air but it's not cold and the compressor isn't engaging?
  5. Jun 26, 2023 at 4:51 AM
    Electrician
    2015 Tacoma tad 4/4
  6. Jun 26, 2023 at 4:55 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Then either the system is low or empty on refrigerant or there is a problem with the refrigerant pressure sensor or circuit or evaporator temperature sensor or circuit.
    I think the next step would be to put service gauges on it and verify there is refrigerant in the system.
  7. Jun 26, 2023 at 6:07 AM
    Electrician
    2015 Tacoma tad 4/4
    Does it have a head pressure switch. Some pressure switches are resettable.
  8. Jun 26, 2023 at 6:45 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Just a dual pressure switch but it's self resetting, it's off below about 24psi or above about 455psi.
    It's on the liquid line below the radiator support on the right side, you could momentarily bypass it to make sure the compressor comes on but the refrigerant really should be checked with gauges.
  9. Jun 26, 2023 at 8:39 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Electrician?
    Clogged air filter on a fan / blower will draw less current, not more. But if you will feel better checking a fuse check the 50 Amp Heater fuse that supplies the fan power and IG1 No2 10 Amp Fuse that supplies the heater Relay and the power to the Magnetic Clutch.
    But as stated above by Dm93 if blowing air but it's not cold and the compressor isn't engaging it is probably low on R134A.
    Dm93 likes this.
  10. Jul 23, 2023 at 5:13 AM
    duque00
    duque00 Well-Known Member
    Long Island, NY
    Any recommendation for refrigerant hoses? Compatible with R134a please.
