AC wiring for remote start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by will.i.was, Jun 30, 2019.
  1. Aug 11, 2020 at 3:41 PM
    namiam
    namiam Member
    This thread has been helpful. Do you have any recommendations to start AC using the CM900 module (1 jumper)? I am having same issue has OP.
    Right now, I have
    yellow (starter) to green/black
    green (ign) to black/red
    blue (2nd ign) to blue/yellow (jumper on 2nd ign as it is by default)
    green/white (+ parking light) to green
    white (acc) to white/green
  2. Aug 11, 2020 at 9:09 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    You must wire it the way I posted. The starter wires needs power on crank and the ignition wire need power constantly on ignition and during crank. It’s vital for all components and modules to have the correct power when needed or things won’t function and you can get dash warning lights. See post #13. The CM900 unit is a little different. So you won’t be able to use that parking light wire to power anything other than + parking lights. You will need to power both starter wires. They should be isolated with a relay or large diode. Some people will just run a wire from one of the start wires to the other to basically jump the circuit. This is not the proper way to do it. If you want to avoid external relays or diodes you’ll want to get a cm7000 brain (Compustar FT-7200s)
    will.i.was[OP] likes this.
  3. Jan 10, 2022 at 7:53 PM
    motoman1150
    motoman1150 New Member
    Brandon
    2015 Tacoma Double Cab Long Bed
    To isolate the the starter wires with a relay are you wiring the yellow starter from the CM900 to a trigger on two relays, one to the black/white starter wire and the other to green/black?
  4. Jan 11, 2022 at 1:29 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Correct. Or you could use one of the wires in the secondary harness and use the POC to make it a selectable - starter wire to trigger the relay. Then just feed 12v to the other side of the relay coils
