Ac won’t blow hot air.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dylan Oliver, Jan 16, 2025.
  1. Jan 16, 2025 at 2:31 PM
    Dylan Oliver
    Dylan Oliver [OP] New Member
    Dylan
    2011 trd
    Headlights
    I’ve been having this issue recently and was wondering if anyone else has had it.
    But AC blows cold just fine but won’t blow hot air unless I’m ripping on the highway. So I know it can blow hot and I’ve checked the coolant but just normal driving around the city it won’t heat up.
    Anyone had the same issue / know what could be causing it.
  2. Jan 16, 2025 at 2:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Jan 16, 2025 at 2:42 PM
    Dylan Oliver
    Dylan
    2011 trd
    Headlights
    I’ll check it out thank you
    TnShooter likes this.
  4. Jan 16, 2025 at 9:05 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    Might also want to check your coolant level and make sure you don’t have any leaks, if it’s too low you won’t get a lot circulating through the heater core IIRC.
    I have a 4cyl so mine doesn’t move too great at idle but I’m assuming you have a v6?
    Does your blower move air well with the different fan speed settings when set to cool or with the AC on? The blower motor resistors are a bit of a weak point and sometimes fail.
