ac wont blow cold air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justus, Nov 10, 2014.
  1. Nov 10, 2014 at 1:00 AM
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    On the way home I flipped the ac on and waited...... And waited...... For ambient air?
    The fan works at all speeds, just blowing warm air.
    DA fuq?:eek:
    Now, the rpm raises and the truck lurches from a stop when I select the ac and turn it on...... Like its running, but never gets cold.
    No belt issues known..... Any idea what to check before I take it in?
    I imagine ur gunna say fuses...... Couldn't the surging rpm and lurch from a stop indicate the compressor running?
    2006 taco, 80K never had ac service or problems before this.
  2. Nov 10, 2014 at 2:24 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    If the compressor is spinning then you are looking at either the compressor internals went bad, the "Freon" is low or maybe its as simple as the inside vent doors that open and close when you adjust the temp knob are broken. Thats the cheaper fix.
  3. Nov 10, 2014 at 3:54 AM
    Aztecs
    Aztecs Well-Known Member
    Jose
    Goodyear, Arizona
    2012 DCLB V6 4x4 SR5
    Debadge, Tailgate lock, 3" ProComp Suspension Lift, ProComp wheels and tires, Volant CAI with ram air scoop.
    Check your cabin air filter.
  4. Nov 10, 2014 at 2:41 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Cabin air filter is good.
  5. Nov 10, 2014 at 3:11 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Feel the return hose/pipe for the AC (it's the larger one) and see if it's cold if so you got a door problem.
  6. Nov 10, 2014 at 4:20 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    x2
  7. Nov 10, 2014 at 5:28 PM
    Reymundo88
    Reymundo88 Well-Known Member
    Rey
    05 Tacoma TRD Off Road
    Installed K&N Cold Air Intake
    I had the same issue, engine would rev up and down almost as if it wanted to turn off, squealing noise would sometimes be present, last but not least the light on the ac button sometimes would stay blinking. Unfortunately this happened to me twice!!! Once at about 70k and again at 110k. Compressor was locking up on both occasions.
  8. Nov 10, 2014 at 5:29 PM
    Reymundo88
    Rey
    I hope that's not the case with you because it was expensive to replace the entire ac system.
  9. Nov 10, 2014 at 8:12 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Had compressor lockup in my previous car. Ended up sending metal shavings through the lines and ruined my condenser, too. At that point I had to replace the entire system.
    Hopefully that's not your case, or at the very least that you catch it when it's just ONE component.
  10. Nov 11, 2014 at 3:43 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Check your ac switch. Might be able to find someone around town that would switch out with you to see if that's the problem
  11. Nov 11, 2014 at 9:53 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
