AC working intermittently
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06 tacoma owner, Jun 30, 2014.
  1. Jun 30, 2014 at 1:16 PM
    06 tacoma owner
    06 tacoma owner [OP] Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    My AC is only working when it wants too. When i first start it up and drive it wont start working until i drive it for a little bit and sometimes it just plain up doesn't work at all. Suggestions?
  2. Jun 30, 2014 at 1:57 PM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    If you haven't already checked, unhook the glove box door and remove the cabin air filter. Make sure it isn't clogged and while you're at it, reach in and check for any leaves or anything else that might be blocking the fan.
    Is it only working at the third or forth speed setting or does it sometimes work for all speeds, not just the higher speeds?
  3. Jun 30, 2014 at 5:31 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Possible intermittent blower motor?....
  4. Jun 30, 2014 at 5:41 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    You need to define intermittent operation. These fans/resistors/resistor connectors are prone to failure. If its fan related, it's probably one of these 3, if it's not the fan, you're probably low on gas.
    Be advised that if you compressor is running properly and your fan shuts off, you will freeze you're evaporator coil in the dash and you will have zero airflow until it thaws.
