AC60F VERY rough 3-4 shift over 6000rpm
Discussion in 'Performance and Tuning' started by black3rdgen, Nov 24, 2024.
  1. Nov 24, 2024 at 8:47 AM
    black3rdgen
    black3rdgen [OP] Well-Known Member
    STL
    3G on 35s, 5.29s
    YW E30 tune, 5.29s, equal length dual exhaust, 2000w audio system
    My truck has been doing this for as long as I’ve had it, and it’s not showing any signs of wear as far as I can tell. The 3-4 shift is 100% fine until over 6000rpm ish. Telling me I shouldn’t run the truck super hard won’t help me, I just want to know what could be causing this. Not a big issue it seems like, just kinda odd.
    https://youtube.com/shorts/JmLjYHDPIS4?si=rute_d_jLO0NLFta
    In the first clip of this video is the rough shift over 6000, 2nd clip is just a normal shift.
    The harsh shift feels like the car is getting rear ended. It’s an insanely violent slam, I think you can hear the tires chirp in the video. Like I said though, no signs of wear and no metal in the trans oil.
  2. Nov 24, 2024 at 12:18 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    That don't sound good or normal. My wild guess would be to check your aftermarket gears, tune, drive shaft, u-joints and trans fluid level.
  3. Nov 24, 2024 at 3:03 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    I’m gonna rule the gears out because it did it on the stock 3.91s or whatever they are. Also kinda ruling tune out because it’s done it on KDmax and Yotawerx. I just had the fluid changed and there was no metal in the oil, so I’m really lost on this. It’s showing 0 signs of damage but it feels like it’s getting hit by a semi truck every time it does it.. guess I’ll just have to avoid that shift. Whatever
  4. Nov 24, 2024 at 3:31 PM
    Canadian Caber
    Les
    B.C. Canada, eh
    That don’t make sense. Strange issue. I’m stock with OTT and factory gears. I’ve done a number of 6.5k shifts without that concerning noise.
    Other thing is how it’s intermittent. Maybe something in your torque converter?
    Did you go out and see if the driveshaft has any play in it? Also the U-joints?
    Maybe @Vlady or @TnShooter might have some ideas.
  5. Nov 24, 2024 at 4:41 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Haven’t checked the driveshaft yet, gonna do that tomorrow. I’m really confused though because it’s exclusively on the 3-4 shift over 6000. I can shift into any other gear over 6000rpm no problem, I can shift at 7k in 1st and 2nd. Have you tried a 3-4 shift in manual mode bringing it up to 7k? I’d really like to know if another truck does this. You might have to go pretty fast to hit that shift if you’re on big tires though. I’m pretty sure when I was on stock gears and 33s i made that shift at 80 or 90 something mph.
  6. Nov 25, 2024 at 10:49 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I would check if you are not hitting a fuel cutoff rpms, speed governor, etc.
    Check tranny output shaft rpms during these shifts.
  7. Nov 25, 2024 at 2:24 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Fuel cutoff is 7000rpm. Speed limiter is tuned out. Just checked the driveshaft and all is well, so I really have no idea.
  8. Nov 25, 2024 at 2:49 PM
    Vlady
    Issy, WA
    I would still datalog parameters and go from there. Tranny output shaft rpms are used in shifting schedule tables. So if you are tuned, have them look at specific region of operation that cause the issue.
  9. Nov 27, 2024 at 5:29 PM
    guest_707
    guest_707 Well-Known Member
    Holy shit you can make these trucks rev up to 7k?
  10. Nov 27, 2024 at 5:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Should smooth out at 8k rpm
    Canadian Caber likes this.
  11. Nov 27, 2024 at 7:15 PM
    Canadian Caber
    Les
    B.C. Canada, eh
    :rofl::rofl::rofl::rofl:
    Steves104x4[QUOTED] likes this.
  12. Nov 27, 2024 at 7:17 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    black3rdgen[OP] likes this.
  13. Nov 28, 2024 at 8:47 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Yeah the 2GR is a very rev happy motor. I think the Camrys and IS350s stock rev limiter is at 7000. RR racing tune bumps it to 7400. More than safe to run the motor this high up, trans doesn’t seem to love it tho :rofl:
    guest_707[QUOTED] likes this.
  14. Nov 28, 2024 at 8:48 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    How about 9,000? 10,000? What’s stopping us??
