Acanni headlights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by IEsurfer, Aug 11, 2020.
  1. Aug 11, 2020 at 3:59 AM
    IEsurfer
    IEsurfer [OP] Well-Known Member
    Socal
  2. Aug 11, 2020 at 4:06 AM
    Harryhood87
    Harryhood87 Well-Known Member
    Harry
    New England
    2004 Xtra Cab 4x4 Lunar Mist 260k+
    265/75/16, Yak Q towers
    I believe most of those reviews are given immediately after install and not after months of use. Search around here for information regarding 1 piece headlights. I think one of the issues is they aren't sealed well and develop moisture inside. Some folks drill a hole in the bottom of the light before install to improve air flow or reseal the lenses themselves.
  3. Aug 11, 2020 at 6:18 AM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    I bought a set of TYC headlights and they looked pretty close to a factory housing.... but I retrofitted them with some Morimoto M-LED projectors.
    StevenP and IEsurfer[OP] like this.
  4. Aug 11, 2020 at 9:51 AM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    I’ve had two sets of Amazon/eBay aftermarket lights, first set got crunched in a fender bender, on my second now. I can’t speak to the longevity of either, but fitment and initial impressions are good.
    IEsurfer[OP] likes this.
  5. Aug 11, 2020 at 10:12 AM
    umpire3
    umpire3 Well-Known Member
    Robert
    2004 Tacoma 4-door, V6
    Subscribed.
  6. Aug 11, 2020 at 10:26 AM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Aftermarket headlights fade and turn yellow. Also the adjusters usually dont work or break. The last concern is the beam pattern is typically terrible.
    That being said, I have a set on my truck, I replaced all the adjusters and did a bi-xenon conversion. They have only been on for a year or so. I expect them to eventually fail, but for $100 I'm ok with it.
  7. Aug 11, 2020 at 10:32 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I ran the single piece headlights (with the led strip below the headlight) for over a year with no problems.
    I have since done retrofit headlights (meaning I have resealed them as a part of doing the retrofits) still, no problems.
    StevenP likes this.
  8. Aug 11, 2020 at 11:26 AM
    Plkyone
    Plkyone Well-Known Member
    Oh those are the two piece light unless you definetly want the lights with the black background I would go with TYC lights they would be a much better quality than those. I have had a few sets of lights and the TYC are by far the best aftermarket fit, I'm just going to retrofit mine to change the look.
