Accel Ignition Coils
Discussion in 'Performance and Tuning' started by shr133, Jan 14, 2015.
  1. May 21, 2016 at 9:19 AM
    #61
    GHOST TACO
    GHOST TACO Well-Known Member
    NOE
    SEBASTIAN TEXAS
    2019 TOYOTA TACOMA DBLCB.TRD OFFROAD 4x4
    American tonneau cover
    read this all this post.and just pulled the trigger on some of these accel coils from summit.they have them right now in a 4 pack for $183.95 free shipping for my 2.7l.lets see how these things work on my taco.
    steezinstangl and Torspd like this.
  2. May 24, 2016 at 7:54 AM
    #62
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    looking forward to your thoughts on them!
  3. May 24, 2016 at 4:07 PM
    #63
    GHOST TACO
    NOE
    SEBASTIAN TEXAS
    i should receive them today .i will put them on tomorrow.and lets see how they do.i am curious.put them on my 2001 ford ranger with a 4 cyl.and it woke that thing up.i will let you all know.
  4. May 24, 2016 at 6:32 PM
    #64
    GHOST TACO
    NOE
    SEBASTIAN TEXAS
    they came in early.I had to put them on and try them.First impression,i turned the truck on after the install.it idled the same no difference.thought to myself ,guess i just have some great looking yellow coils.When i drove it ,Damn.coming from a 4.0 tacoma to this 2.7.WOW. crisper take off,exhaust became throatier.going around the corner feel when you step on the throttle a bit.it takes off with a little more umph.I wanted to see what it would do down the highway going over the overpasses and holding 70 miles an hour against the wind.today we have 30 to 35 mph wind gusts.i am happy it kept pace with the wind against it.before it would have problems going up the overpass with wind gusts in the same mph.she picks up a whole lot better.
    took it to a dirt pit and put it in 4x4.now this little truck has never had a problem in the dirt in 4x4.its a mean little shit in the dirt..well i changed her name today to the digging armadillo.cause it just got meaner and more powerful in the dirt.hit the throttle on a freshly disc'd field and it pulled great.even better.If you ask me this is the best $183.00 i have spent on this truck.i can only guess what it would do to a 4.0l.i will drive it pulling my trailer with two round bales for my cows and we will see what it does with a good load on it.i will let you know.happy.:thumbsup::bananadance::yay:
    shr133[OP] likes this.
  5. May 24, 2016 at 6:49 PM
    #65
    ThomasMore66
    Dallas/Fort Worth & Durango
    Now I want some.
  6. May 24, 2016 at 6:51 PM
    #66
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I installed on 06 with 4.0 urd sc'd stage 3 on 35's. I found no considerable difference at all.
  7. May 24, 2016 at 6:56 PM
    #67
    ThomasMore66
    Wet blanket. Don't kill the dream.
  8. May 25, 2016 at 5:06 PM
    #68
    GHOST TACO
    NOE
    SEBASTIAN TEXAS
    Well i ran it to work long commute.hell not afraid to get on the on ramp and puching it .it felt stronger than it was.passed a truck against the wind no problem.for me its great.love it.
  9. May 26, 2016 at 11:56 AM
    #69
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Hmmmm wonder if these would be worth it on mine...
  10. May 26, 2016 at 4:42 PM
    #70
    GHOST TACO
    NOE
    SEBASTIAN TEXAS
    alot of wind today from the south.doing 70 before was very hard against the wind.its alot better now.will get a tonneau cover for it to try to get better aero dynamics.what do you all think about a tonnaeu?
  11. May 26, 2016 at 4:58 PM
    #71
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    You do know that Holley which has acquired Accel and other brand mfgs has just signed a deal to have all of their parts mfgd in China . Holley will still design & market them but all perf parts to be mfgd off shore
    Now this may say hey why not then go with MSD !!!! , guess what Holley bought MSD just after MSD bought out MALLORY ign . So same thing it will be an off shore mfgd part
    Sorry I'm not buying any chinesium perf parts , I'll stick with American made parts
    Now if you want your motor to idle smooth and keep the plugs clean then look into a MSD 6A box or even step up to a MSD 7AL2 or MSD7 AL3
    Torspd likes this.
  12. May 26, 2016 at 5:14 PM
    #72
    GHOST TACO
    NOE
    SEBASTIAN TEXAS
    First off THANK YOU FOR YOU SERVICE:oldglory:.Wow i did not know these perf.parts are going to be chinese .well i guess we will have to find some other company to get our perf.ignitions.
    but i dont think we can put a msd 6a on our trucks.we have individual coil packs.correct me if i am wrong
  13. May 26, 2016 at 5:30 PM
    #73
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Like I mentioned HOLLEY bought out MSD , MALLORY and ACCEL that doesn't leave much for ignition mfgs that still build onshore . As for MSD boxes they do work with coil packs such as GM LS motors , Ford mod motors so I don't see why it shouldn't work on our motors
  14. Jun 2, 2016 at 8:32 AM
    #74
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Hmm, you are right about Holley buying MSD but I have buddies that work there ( I did as well back in the day) and as far as they are telling me they are still making product at the plant in El Paso. My caveat is which product they will continue to make there I don't know.
  15. Jun 3, 2016 at 2:52 PM
    #75
    GHOST TACO
    NOE
    SEBASTIAN TEXAS
    Well,driving the coils for a week and no complaints.today driving thru a thunderstorm with high winds put the auto in 3rd and no lag,no drag,no hesitation.it plowed thru it with two inchs of water on the freeway doing 35mph.i was passing trucks with lift kits cause the visibility was bad and the road was saturated with water(rain x on the windshield it works).before with the old coils different story.with the old coils it felt like i was dragging a :deadhorse:.i am very happy.i have no complaints.
  16. Jun 9, 2016 at 8:36 AM
    #76
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I'm just curious for those that have replaced the coils. Do you think it's because you've replaced worn out coils that you are seeing improvements? I wonder if you would see the same results with new OEM coils.
  17. Jun 9, 2016 at 6:15 PM
    #77
    GHOST TACO
    NOE
    SEBASTIAN TEXAS
    my coils were new.stealership replaced them when i bought the truck.so before i placed the accel coils i put new spark plugs and it ran good.but when i replaced the coils for the accel ones i noticed a difference.its alot more powerful in my opinion.i am happy with them ,i spent my money good.
    Revelations likes this.
  18. Jun 16, 2016 at 11:55 PM
    #78
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Actually. The only MSD box which would work for ours (you would have to run 2) would be the DIS-4. They are insanely expensive for the record.
  19. Nov 21, 2021 at 12:55 PM
    #79
    chromebumper
    chromebumper New Member
    Reid
    2008 Toyota Tacoma 2.7 Base 2WD
    ACCEL coils 140495
    Installed 4 accel 140495 coils on 4/21. 4 have failed. 50% rate in 7 months. Although wonderful improvement, already had to replace 2. Emailed Accel on issue and awaiting response.
  20. Nov 21, 2021 at 1:01 PM
    #80
    Clearwater Bill
    Billy
    Largo Florida
    You posted in a thread that ended well over 5 years ago.
    The product itself could have undergone significant changes anywhere from design to manuf. to QC processes in that time.
    Or you could just be unlucky.
    SUMOTNK likes this.
