Acceleration problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by max89er, Oct 16, 2012.
  1. Oct 16, 2012 at 5:03 PM
    max89er
    max89er [OP] New Member
    max
    Moncton,NB Canada
    2005 Tacoma Trd
    hi i have a 2005 tacoma v6 4.0L started hesitating upon acceleration, especially around 2000 RPM. Then I give it some gas, it goes, then slows, then goes then slows but when i floor it everything is good just when she forces it seemed like the cats where plugged so i unpluged the rear back ones.... no difference when i went to check the two front ones there was already nothing in them just wondering maybe my problem was because the two front ones where already unpluged or this is not related at all to the problem
  2. Oct 16, 2012 at 5:05 PM
    badger
    badger Well-Known Member
    07 SR5
    Have you ever cleaned your throttle body and MAF? If not I would start there.
  3. Oct 16, 2012 at 5:08 PM
    max89er
    max
    Moncton,NB Canada
    2005 Tacoma Trd
    yeah did that evrething is good there
  4. Oct 16, 2012 at 5:09 PM
    max89er
    max
    Moncton,NB Canada
    2005 Tacoma Trd
    what do you thing about the cats would that be the problem??
  5. Oct 16, 2012 at 5:28 PM
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
    How recent did you clean the throttle body? I did mine today and experienced the same thing.
    You need to disconnect the battery for about 10 minutes or so to let the computer reset. The issues went away for me. Drives well now.
  6. Oct 16, 2012 at 5:29 PM
    photonashville
    all my posts are magically double posting today. time to restart the computer.
  7. Oct 16, 2012 at 7:23 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    If a cat is plugged it'll sound like it's farting out the intake. It will run fairly well at low throttle, worst at full throttle. I had a honeycomb turn sideways and jam into the outlet on my Civic a few years back - not fun. I could barely drive home because it wouldn't go over 2500 rpm unless I really eased it there.
    Almost sounds like A/F sensor to me if it runs fine at full throttle. Any pending codes?
  8. Oct 16, 2012 at 7:29 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Fuel filter? Plugs? Cheap things to check first.
  9. Oct 17, 2012 at 3:47 AM
    max89er
    max
    Moncton,NB Canada
    2005 Tacoma Trd
    changed the plugs last week gapped and evrything filter clean cleaned the maf the fuel filter is on the pump in the gas tank big job changing that
  10. Oct 17, 2012 at 3:59 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    interesting that the problems started only a week after several major maintenance projects. I would recommend you check the work you did. Maybe a faulty plug you installed or one slipped loose. Maybe damaged a spark plug cable or solenoid. My guess is when you cleaned the MAF it threw off the computer as mentioned already. Disconnect battery for awhile (id say 30+ minutes to be safe :notsure: ) then drive atleast 100 miles (not all at once) and im sure it will re-learn everything and problem go away. common after MAF cleaning.
  11. Oct 18, 2012 at 7:10 AM
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I would say pop the boots off the plugs and make sure no broken plugs and make sure to get them back on tight.
