Acceleration Problemo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ivansal, Nov 25, 2011.
  1. Nov 25, 2011 at 11:24 AM
    ivansal
    ivansal [OP] Member
    Ivan
    Southern AZ
    2005 Tacoma TRD
    First, you should know this is very difficult to explain but here we go.
    I have a 2005 tacoma quad cab, 90,000 miles (2 wheel drive)
    About last week i starting noticing a strange vibration from the engine or possibly the transmission. It seems when i start reaching the 25mph is when the vibration starts, and I also noticed that the rpm are at about the 1800 rpm. As if the transmission is having a hard time switching gears. I wanted to get your insight on this before i take it to be checked out. maybe its something i can fix with the assistance of you good folks.
    I dont know what other details i can provide that would help, but i am willing to try any troubleshooting suggestions.
  2. Nov 25, 2011 at 11:25 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Look at your u-joints
  3. Nov 25, 2011 at 11:36 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    ^^^x2 U-joints might be going bad. Crawl under your truck and check for excessive play in the joint. It's easier to replace a $135 U-joint versus a $2000 transmission.
    Also, when was your last major service? $200 in parts and a weekend in time could solve your issue.
    -Spark plugs
    -Diff oil
    -Tranny drain and fill
    -Throttle body cleaning
    -MAF sensor cleaning
    -Engine oil and filter
    -Air filter
    -Fuel Injector cleaning
