Acceleration vibration 2017 Toyota Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Xer17, Jan 6, 2017.
  1. Jan 6, 2017 at 7:48 AM
    Xer17
    Xer17 [OP] Member
    Double-Cab Limited
    Hi guys,
    I am a first time Tacoma owner and I had a few questions....I had recently picked up a 2017 Tacoma double cab limited and noticed slight vibration under the gas pedal from approx 2200 to 2600 rpm. Either I am being a slight hypochondriac as I have read this issue for the 2016 or are some people dealing with this issue in the 2017's as well. Any feedback would be awesome!
  2. Jan 6, 2017 at 7:49 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Jan 6, 2017 at 7:54 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    The 2017 is literally the same exact truck. They exhibit almost every single issue that the 2016s had, with very very few exceptions. Even the Lower Control Arm holes are not plugged on the 2017 which you'd think Toyota would have gone ahead and done for the new model year as it was already a TSB for the 2016 and a VERY easy and cheap fix, but they did not.
  4. Jan 6, 2017 at 7:59 AM
    CJREX
    CJREX Well-Known Member
    Georgia
    But hey, Mike Sweers promises that he'll buy you dinner if you find a 3rd gen with vibrations.
    https://www.tacomaworld.com/threads...xed-the-drivetrain-vibration-for-2016.376328/
    You may want to check the U-bolts on the rear springs as many are coming from the factory too loose.
    https://www.tacomaworld.com/threads/check-your-u-bolts.397913/
    If tight, take it to the dealer and get it documented.
    If they say, "It's normal" contact corporate.
    Do a google search and you'll find lots of info on Tacoma driveline vibrations.
    smitty99 likes this.
  5. Jan 6, 2017 at 8:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    Mechanically. But not 100% cosmetically. You can pay more and get a wet primer color.
    Similar to some mid 90's domestics, like the Taurus. :D
    elduder, 0210 and smitty99[QUOTED] like this.
  6. Jan 6, 2017 at 8:50 AM
    ElGatoLoco
    ElGatoLoco Well-Known Member
    '17 DCSB TRD Sport
    Take it back before it's too late.
    Mush Mouse likes this.
  7. Jan 6, 2017 at 9:07 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    More bad information from Smitty.
    It's not the exact same Truck. For example, my 2017 came with Rev 0 ECU/TCU update. It also had the modified springs/steering damper with the shim to change the angle of the differential and mine has no vibration as a result. All the 2017s should also have the new CPS sensor. Some TSBs are making their way into to the production 2017s, depending on when it was manufactured but there are at least 3 updates that my 2017 had with no symptoms to the problems they fixed.
    Let's also not forget that all 2017 Double Cab TRD/Limited models got the power sliding rear window.
    Xer17[OP] and Mush Mouse like this.
  8. Jan 6, 2017 at 9:18 AM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    How do you know what rev your update was on your 2017, ie 0 vs 1?
  9. Jan 6, 2017 at 9:32 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Techs hooked it up when I bought it to verify it had the updated version at the time, which was pre Rev 1. You can check yourself using a bluetooth OBD2 reader and app like OBD Fusion. If the ECU version ends in 200 it's Rev 0. If it ends in 300 it's Rev 1.
  10. Jan 6, 2017 at 10:12 AM
    dusman
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    Cool, thanks
  11. Jan 6, 2017 at 10:52 AM
    smitty99
    Scottsdale
    Nice try but swing and a MISS. Your comment has nothing to do with the OP issue. The software update has no impact on the mechanical issue of vibration. Not bad information at all as I mentioned they are identical with "very very few exceptions"
    Hank Heel and ChadsPride like this.
  12. Jan 6, 2017 at 10:56 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I just don't understand. I'm not having any issues with mine. I did however notice the constant shifting thing everyone was talking about. But after 300 miles its seems to have settled and is already shifting very smoothly.
  13. Jan 6, 2017 at 11:14 AM
    smitty99
    Scottsdale
    I still see dodge caravans on the road sometimes too....I mean you understand that quality control issues don't necessarily affect 100% of every product that roles out of the factory the exact same
    Meangreen2 and Riding Dirty like this.
  14. Jan 6, 2017 at 11:14 AM
    chuck1986
    chuck1986 Two in the Taco one in the Prius
    Tulsa, OK
    2017 TRD-OR Blue
    The only thing to understand about 80% of the complaints is hypochondriacs. Smitty alone has created a list of "issues" some as sad as my dash rattles when I go over bumps. Now he has about 3 or 4 members who worship him and "have" the same issues.
    Scarab, kerrdog and Mush Mouse like this.
  15. Jan 6, 2017 at 11:15 AM
    chuck1986
    Tulsa, OK
    2017 TRD-OR Blue
    Yet there are several post made by YOU saying all 3rd gens are lemons and we lack the situational awareness to know any better. Interesting...
    Scarab and Mush Mouse like this.
  16. Jan 6, 2017 at 11:16 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    false idol:D
    Scarab and chuck1986[QUOTED] like this.
  17. Jan 6, 2017 at 12:59 PM
    MSCOFF
    MSCOFF Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    Do you know if this information is available using the Torque app for Android? Thanks
  18. Jan 6, 2017 at 1:08 PM
    Usmc341
    Usmc341 Member
    Las Vegas
    2017 Magnetic Gray Metallic TRD Off Road
    Looks like your transmission is adapting to your driving style. After 750 miles mine has done the same.
    LivinOnEdge[QUOTED] likes this.
  19. Jan 6, 2017 at 1:14 PM
    Usmc341
    Usmc341 Member
    Las Vegas
    You think this is bad go on the Hellcat forums. One guy lemoned his car because the front facia didn't align perfectly. And I'm talking millimeters. Another wanted a new car because rock chips were messing up his lower fenders and doors. Said the paint was too thin. I could go on and on
  20. Jan 6, 2017 at 1:16 PM
    chuck1986
    Tulsa, OK
    2017 TRD-OR Blue
    Honestly sounds EXACTLY like him....
