Acceleration When Not on Gas Pedal
Discussion in '1st Gen. Tacomas (1995-2004)' started by tram, Sep 24, 2013.
  1. Sep 24, 2013 at 4:14 AM
    tram
    tram [OP] Well-Known Member
    Timmins, Ontario
    2000 3.4L V6 4wd
    3'' Ultimate Toytech suspension lift: - Front Bilstein HD 650lb coils - Light Racing 25460 Upper Control Arms - OME Dakar Leafs - Rear Bilstein 5100 Extended length rear nitrogen gas shocks -Magnaflow performance Catback -ARB Deluxe Winch Bumper -Bushwacker Extend-A-Fender flares
    I have a 2000 5 speed manual and the strangest thing happened to me this morning on my way to work. I was driving along as usual and let go of the gas in preparation for a stop, and my truck started speeding up a bit. My foot was completely off the gas pedal. At first, I thought it was my imagination, but it happened to me about 3 times on my 5 minute drive to work. I even noticed the engine started revving up on it's own between shifts at one point. Has anyone else experienced this? What the heck could this be?
  2. Sep 24, 2013 at 6:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I would check all your throttle connection & cables. Make sure nothing is 'sticking'.
    Does this symptom just go away on its own? Or what have you been doing to stop it?
    When it happens.... (while in Neutral), STOMP on the gas pedal hard & quick...see if that getx rid of the surge. If it does, I'm betting something in the throttle cabling setup is sticking.
  3. Sep 24, 2013 at 6:39 AM
    tram
    Timmins, Ontario
    2000 3.4L V6 4wd
    Thanks for the reply. I didn't have time to do thorough troubleshooting yet, because I'm at work. Someone suggested it might be condensation in the tank/water in the gas, because it was a pretty frosty morning, but I've never had that happen before. (we get worse mornings than that).
  4. Sep 24, 2013 at 7:38 AM
    Janster
    Jandy
    Lancaster, PA
    Common sense could tell me.....condensation in the fuel lines probably won't cause the engine to surge. If anything, condensation would cause it to stumble and lack power. :confused::confused:
  5. Sep 24, 2013 at 10:03 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If your A/C or defroster is on, then that would cause an increase in idle, when the A/C compressor kicks in.
  6. Sep 24, 2013 at 12:36 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Yep
  7. Sep 25, 2013 at 9:14 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Bad Tps sensor can cause revving like that also
  8. Sep 27, 2013 at 10:41 AM
    tram
    Timmins, Ontario
    2000 3.4L V6 4wd
    Thanks for the info. Strange, but I haven't been able to reproduce the problem since. I'll update if it happens again.
  9. Nov 6, 2014 at 9:50 AM
    tram
    Timmins, Ontario
    2000 3.4L V6 4wd
    Been a while, but thought I would update. Problem came back. Took it in and it turns out that a dirty throttle body was the culprit. Cleaned it out and replaced a flap inside. Been good ever since.
  10. Nov 6, 2014 at 10:02 AM
    Large
    Large Red
    Good stuff. Usually when people post an issue they don't revisit the thread and update the solution, good job.
  11. Nov 6, 2014 at 10:17 AM
    tram
    Timmins, Ontario
    2000 3.4L V6 4wd
    Ya, I didn't want to be "that guy" :)
    Spread the knowledge, I say.. That's what these places are for.
