acceleration whining noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sky59, Sep 1, 2022.
  1. Sep 1, 2022 at 7:57 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    I'm having a problem with having a whining noise when I accelerate when I rev in park the noise is gone could this be a transmission problem?
  2. Sep 1, 2022 at 8:30 PM
    Aircates
    Aircates Well-Known Member
    Texas
    1997 Tacoma lowboy
    Could be in the differential. Is this a stick or automatic?
  3. Sep 2, 2022 at 5:30 AM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    automatic
  4. Sep 2, 2022 at 6:16 AM
    eNtropy
    eNtropy Member
    Nate
    Michigan
    '04 V6 5-speed
    3" OME lift, 285/75/16 BFG A/T, HID Projector retrofit
    Did someone install a supercharger when you weren't looking?
    Green1GT and noodles93 like this.
  5. Sep 2, 2022 at 8:07 AM
    mbeers6
    mbeers6 Well-Known Member
    East bay, ca
    03 tacoma double cab 4wd
    Air filter
    How many miles on your truck? I had a whine from rear of truck and turned out to be pinion bearing (at 225,000 miles).
  6. Sep 2, 2022 at 9:19 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Need more information or video.
    Try to find location of noise. You could possibly jack the rear tires up and see if will make the noise with no load and find location For better help.
  7. Sep 2, 2022 at 9:42 AM
    Madjik_Man
    Colorado Front Range
    My torque converter and/or transmission pump whine.
  8. Sep 2, 2022 at 5:15 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    140k
  9. Sep 2, 2022 at 5:16 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    ill get a video tomorrow when i have time to work on it the noise seems to be at the driverside fire wall near brake booster
  10. Nov 15, 2022 at 7:06 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I wonder if this is what I'm hearing. I don't know if it's the transfer case or drive shaft but I definitely can hear a difference when accelerating, especially hard acceleration. New to me transmission going from my stock 340E to this 99 4Runner 340F. Both have roughly the same mileage - about 160k.
    I do not want to pull the transmission. SOB.
  11. Nov 15, 2022 at 7:07 AM
    Area51Runner
    Did you ever figure this out?
  12. Nov 15, 2022 at 9:58 AM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    Does this happen when your wife is in the passenger seat ??
  13. Nov 15, 2022 at 6:34 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    sure did the hose on the bottom of the vacuum solenoid had a crack
