Acceptable amount of thread to stud engagement
Discussion in '1st Gen. Tacomas (1995-2004)' started by clayshutr, May 2, 2018.
  1. May 2, 2018 at 3:38 PM
    clayshutr
    clayshutr [OP] Well-Known Member
    Robby
    Central MO
    02 dc 4x4, 08 T4R v8
    ome 882 billy's dakars 255-80-17 STMAXX SCS F5 some other random doodads
    Okay, how many threads on lug nuts is acceptable clamping? I have 6 1/4 full turns on the lug nuts. The studs could surely be longer and I'd feel better, but is it really necessary?
  2. May 2, 2018 at 3:47 PM
    DevilDogDoc
    DevilDogDoc Well-Known Member
    Moses
    20 TRD OR DCSB
    I learned the amount it thread should be at least as much as the bolt is across? Does that make sense?
  3. May 2, 2018 at 3:56 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    Note: Since the thickness of an alloy wheel can differ from Original Equipment wheels, also verify that the lug nuts or bolts will engage the threads. Refer to the chart (at right) to determine the number of turns or the depth of engagement typical for your stud or bolt size.
    that's from Tire Rack. usually for open ended I like to see the entire bolt occupied by thread, ex. the stud comes all the way through the bolt.
  4. May 2, 2018 at 10:08 PM
    Glamisman
    Glamisman Well-Known Member
    I put longer studs in my 96 4X4 front and rear... really easy to do. The fronts required a little shortening of the new longer stud, maybe 3 threads to get it to feed into the old stud location. I "feel" safer now knowing that I have more than 4 or 5 threads holding on my front wheels.
  5. May 3, 2018 at 6:41 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
