Acceptable Rust and How to Fix?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SnowSpartan, Nov 3, 2018.
  1. Nov 6, 2018 at 3:49 AM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    Terrible rust protector. Check out Boeshield T9.
  2. Nov 6, 2018 at 4:07 AM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Personally I hit my truck with fluid film every year. Two cans will cost you about 10 dollars and an hour to apply it. I didn't even jack the truck up this year, tho you probably should. That will last you a good year of peace and mind. Dont hit the exhaust, it will burn off regardless.
  3. Nov 6, 2018 at 6:52 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    I always figured these would cause more rust, as I'm sure they hold moisture and other things in...
    2016Tacoman likes this.
  4. Nov 6, 2018 at 7:08 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    It’s all just surface rust. Wire brush it off and spray matte black Rustoleum on it. Done.
    Fluid film or Boeshield if you really want to go all out. It does a good job of keeping the leaf springs from squeaking too.
  5. Nov 6, 2018 at 7:15 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Where do you get fluid film for $5?
  6. Nov 6, 2018 at 7:24 AM
    Boricua
    Boricua Well-Known Member
    Jack
    2018 TRD Sport
    That looks amazing! Is this better than the fluid film? How durable is it in comparison to FF?
  7. Nov 6, 2018 at 8:07 AM
    Pine State
    Maine
    Sorry i guess my memory is fuzzy and i misremembered. Its $9 at lowes.
  8. Nov 6, 2018 at 9:01 AM
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    Buy engine enamel and get under your truck. Go to town, never worry.
  9. Nov 6, 2018 at 9:22 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Do you paint it all on the truck? Does it harm any plastic/rubber materials at all - i.e. have to be careful to cover them up and such?
  10. Nov 6, 2018 at 9:26 AM
    ELT2JV
    17 TRD OR ACLB
  11. Nov 6, 2018 at 11:11 AM
    DanRN
    DanRN Member
    Daniel
    Southern CA
    2018 MGM Tacoma TRD Sport 4x4
    That rust is normal and nothing can really be done about it nor should really be done about it.
    melikeymy beer likes this.
  12. Nov 6, 2018 at 11:12 AM
    KVTaco
    KVTaco Well-Known Member
    1. Will one application of Fluid Film last all winter in the Northeast?
    2. Do you want to AVOID spray cleaning the salt and much off while this is on the winter so you don't spray off the Fluid Film?
  13. Nov 6, 2018 at 11:14 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    You are concerned with that?
    SnowSpartan[OP] and Woofer2609 like this.
  14. Nov 6, 2018 at 2:06 PM
    Methadras
    Methadras Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    The rust in these areas might actually be a protectant.
  15. Nov 6, 2018 at 2:10 PM
    #35
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Good advice. RustMort is another similar product. I got to know it well when i owned vintage Datsuns. Apply, and thenwhen dry, paint over with rust paint. Note. Phosphoric acid does NOT play well with galvanized hardware.
  16. Dec 10, 2018 at 10:04 PM
    #36
    Flare side Taco Lover
    Flare side Taco Lover I'm gettin hitched...to my truck!
    Mudder Trucker
    Hicktown Ohio
    03 Taco, 98 Ram, 00 Ranger, 85 Ranger, 03 Ranger, 00 Sonoma
    put truck nuts on my 2000 Ranger
    My frame was so bad on my 1st gen, it had to be replaced. At least the warranty wasn't expired yet!
  17. Dec 10, 2018 at 10:13 PM
    #37
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Lemon law
