Acceptable speedometer error?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stro1965, Nov 24, 2008.
  1. Nov 24, 2008 at 12:58 PM
    stro1965
    stro1965 [OP] Well-Known Member
    Bellevue, NE
    09 Timberland Mica Tacoma 4x4
    Does anyone know what Toyota would consider to be acceptable error on a speedo? Mine if off by a full 5 mph at highway speeds as compared to my GPS. When my speedo says 80, my GPS says 75. It's off a little less the slower I go, obviously.
    I stopped down and made an appointment to have the techs verify it next week but the service writer said he THINKS that Toyota considers anything within 10% to be acceptable. I think that is ridiculous.
    What I THINK might be the problem is that my truck came with 16" tires, whereas most other Tacoma models come with 17's. I'm wondering if all of the Tacoma ECM's are programmed the same?
    The service writer also said that he didn't think there was any way to adjust the calibration, which I found odd. I can't believe it can't be adjusted.
  2. Nov 24, 2008 at 1:05 PM
    Hadoken
    Hadoken Active Member
    I don't have a GPS or anything, but every time I pass one of the speed detectors that the police put by the side of the road here in NC my 05 with 17" factory wheels is off about 3 MPH at 50 MPH. If my speedo says 50, I'm going about 47.
  3. Nov 24, 2008 at 1:06 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    5MPH at 80 doesnt seem too bad to me, i know my truck read about 2-3 mph slow at 60-65 so yours seems to fall in line to me. with my larger tires now mine reads a tad slow if anything. to my knowledge there is no way to calibrate them at the moment. the 16" vs. 17" really wont make a difference, the overall tire diameter is what will make the difference not the wheel.
  4. Nov 24, 2008 at 1:11 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Well, atleast it's showing to high instead of too low. Not knowing you're going 5 mph faster than your speedo shows could get expensive.:burnrubber:
  5. Nov 24, 2008 at 1:36 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Isn't there a way to reprogram it with one of those gismos that allow you to change computer settings. A friend of mine has a Mustang and when he said that when he put on larger wheels and tires, he entered the new tire size into the unit. Maybe he was blowing smoke up my a**...
  6. Nov 24, 2008 at 2:05 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    yeah,(but anyone correct me if im wrong) i think there is a program out there that you can install onto your laptop, and you can ajust the settings on your car computer.
  7. Nov 24, 2008 at 3:47 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Mine came with 265/70/16's. They say if you switch to 265/75/16's it corrects your speedo or at least gets it much closer. Mine is about 2-4 MPH slow compared to the GPS or the Garmin. In about another 20K I will find out because I plan to go with the 75 profile with new tires. :)
  8. Nov 24, 2008 at 4:31 PM
    stro1965
    Bellevue, NE
    When I left the service desk I went out to the salesman who sold me the truck. I bitched about it to him about it and he claimed they'd "make it right" no matter what Toyota says (we'll see). He mentioned swapping out tires for a larger size so maybe I could talk him into a more aggressive tread pattern at the same time.
  9. Nov 24, 2008 at 4:37 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Unless the odometer is also off, which means your warranty expires early.
  10. Nov 24, 2008 at 4:39 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    My speedometer is off by 5 km/h slower that's about 3mph, i have 265/65R17 wheels
  11. Nov 24, 2008 at 4:41 PM
    stro1965
    Bellevue, NE
    Ya know...I never thought about that. Does the speedo error mean that the odometer is racking up miles faster than I actually am? I would think so.
  12. Nov 24, 2008 at 4:47 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
  13. Nov 24, 2008 at 5:11 PM
    RelentlessFab
    Eric
    Sparks, NV
    yep, its a conspiracy.......yay! over size tires = more warranty :D:bananadance:5% larger tire= 37888 miles out of my 36000 mile warranty!
  14. Nov 24, 2008 at 6:09 PM
    stro1965
    Bellevue, NE
    I just found the tire size calculator thing and, according to that, I would need to go from a 265 up to a 305 tire to correct that much error. I assume that this is not an option without a lift kit.
  15. Nov 24, 2008 at 6:14 PM
    Justin626
    Palmer, Alaska
    True, true.
  16. Nov 24, 2008 at 6:23 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Toyota states an acceptable indication error could be as much as 3-6 miles per hour check this link it is for a 05-06 Tacoma but it gives you and idea what Toyota says is acceptable.
  17. Nov 24, 2008 at 7:11 PM
    stro1965
    Bellevue, NE
    Thanks Beeftaco, that chart would seem to indicate that mine is outside Toyota's own acceptable limits. We'll see what they say.
  18. Nov 24, 2008 at 7:49 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Mine was also off until I installed my Lift and new wheels and tires!
    Now GPS is RIGHT ON!!!
    (Maybe Toyota will pay for my lift wheels and tires? The amount i paid to correct the issue... :D just kidding)
  19. Nov 24, 2008 at 7:51 PM
    LonghornTaco
    Minnesota
    Yeah, mine was about 3 mph fast at 65 before the new tires (according to the Scangauge). Now, my speedo is about 2 mph slow at 65.
  20. Nov 24, 2008 at 8:36 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    This doesn't matter because they're the same outside diameter regardless of rim size.
    Everyone who's tested theirs has found the same or similar, approx. 3 MPH off. I tested mine with both GPS and radar and that's exactly what it was. On my Tacoma now, with larger tires (from 30.5" to 31.6"), it's dead on.
