Access Cab - child seat anchor points?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by msting22, Jun 5, 2012.
  1. Jun 5, 2012 at 7:21 PM
    msting22
    msting22 [OP] Well-Known Member
    Marcus
    Powder Springs, GA
    2016 Quicksand TRD Off Road
    WeatherTech - Floor Mats Black out badges General Grabber AT2 TRD Baja Rims
    I've looked but I can not find the answer so maybe someone can help me out.
    I have an 08 Access Cab that has anchor points behind the passenger side but does not have any anchor points behind the drive side.
    Both car seats are forward facing and fit with lots of room but I would like find a way to put in anchor points on the drive side to keep the seat from moving around. (the passenger side is rock solid)
    Has anyone ever tried to add anchor points? If so how did it work out?
    Thanks,
  2. Jun 6, 2012 at 5:50 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    I dont know what year they changed the seats, but on the new ones, there are child seat anchors on both sides, infant seat anchors on drivers side -- which is retarded since an infant seat takes more space and normally the father is the driver and needs the seat more back. I have considered the problem and have determined that the anchor points for the seat belts could support d-rings for anchoring an infant seat on the passenger side.
    Now I understand that you have 2 forward facing seats needing to be installed. If these can be installed with waist band level anchors, you may be able to use the seat belt anchors. If you need a headrest level anchor, I wouldnt know what to suggest.
