Access Cab Dog Platform UDPATE (pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Jan 31, 2010.
  1. Jul 10, 2018 at 4:44 AM
    #281
    Mxmili
    Mxmili Well-Known Member
    Max
    Philadelphia
    2011 base 4x4 2.7l
    Bilstein 5100s at 0 Ome 883
    I bet they make a huge difference, when riding in my friends 09 4Runner limited with the Jbl system I get very jealous.
    Yea, I had some favors from an upholsterer friend of mine to use so he sewed it up for me, I just gave him the original cardboard template I made and it worked out perfect, he had the fabric and foam laying around.
  2. Jul 10, 2018 at 5:03 AM
    #282
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    There are 2 boards, only the back one is bolted down and a piano hinge along the entire length that holds them together.
    I wanted to be able to access everything under it, so it had to be hinged.
    I should point out that I used the 4 bolts that you did not use(Replaced with longer bolts). The 2 you used, I have drilled inlays on the underside so the bolt heads do not hit the board. A few other places have been contoured and massaged as well to get it to lay flat.
    Greenbean[QUOTED] likes this.
  3. Jul 10, 2018 at 5:52 AM
    #283
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Honestly for trying it out and seeing what best serves me I drug out a pressure treated 4x4 post and am going to cut it about 6.5” or 7” and use one in each corner and a shorter one in the middle I think.
    I’m also looking a maybe cutting it in half and making two halves. Not sure but priority is to have it in and level and go from there!
    Also adding a couple d-rings under those bolts for a tie down point. Or even some fancy “L-TRAC” down the road. Some small bungee nets wouldn’t be so bad either. Hahaha
    I need to see if my platform is wide enough for using one of those “twin” bolt holes like you used. I believe there may be enough there to capture it.
  4. Jul 10, 2018 at 6:43 AM
    #284
    Greenbean
    Zack
    Western NC
    10-4 thanks for the update!
    By chance can you post a pic of the board folded open so I can see the hinge?
    I may go that way as it would be nice to have a hinged but strong surface.
    If I remove the whole metal crossmember part I lose my retaining holes for the stock plastic bins which I like the tubs they provide.
    llamasmurf[QUOTED] likes this.
  5. Jul 10, 2018 at 6:47 AM
    #285
    llamasmurf
    Wes
    Northern Ontario
    Sure I will take some pics at lunch when I go home, I left those metal pieces installed because I wanted to leave the tubs they provided as well. I just took the tops off the 2 tubs.
  6. Jul 10, 2018 at 6:50 AM
    #286
    Greenbean
    Zack
    Western NC
    Thanks man!
    I’ve almost convinced myself to do two halves, If you lay a flat piece of board on top of those doors it’s flat as can be, lol...
    Looking at the underside of the doors there are plenty of support cross braces in the plastic. I may drill two holes on it and run a carriage from the top but I’m not wanting to keep putting holes in places, hahaha
  7. Jul 10, 2018 at 12:26 PM
    #287
    OldNeumanntapr
    OldNeumanntapr Well-Known Member
    Santa Maria, CA
    2011 Grey V6 PreRunner Access Cab TRD
    It really looks nice. Bet your dog loves it!
  8. Jul 10, 2018 at 12:28 PM
    #288
    OldNeumanntapr
    Santa Maria, CA
    Sounds like you’re figuring it out what will work best. Be sure to post some pics when you’re done.
  9. Jul 10, 2018 at 5:22 PM
    #289
    llamasmurf
    Wes
    Northern Ontario
    Last thing I need to do is the legs, cut some 2x4 and put some hinges will be my solution.
    FredDarts and amyracecar like this.
  10. Jul 10, 2018 at 5:29 PM
    #290
    OldNeumanntapr
    Santa Maria, CA
    Cool! Looking good.
    llamasmurf likes this.
  11. Jul 10, 2018 at 6:32 PM
    #291
    Greenbean
    Zack
    Western NC
    Dude you rock!
    Looks fantastic man!
    Thanks for getting me those pics too!
    Are those piano hinges at Home Depot or the like?
  12. Jul 10, 2018 at 6:33 PM
    #292
    Greenbean
    Zack
    Western NC
    Oh and will the 2x4 not fit with your back wall in place?
  13. Jul 11, 2018 at 5:16 AM
    #293
    llamasmurf
    Wes
    Northern Ontario
    :thumbsup:
    Yes they are some sort of kitchen cabinet hinge, my buddy who made all this for me makes kitchens and bathrooms for a living.
    The 2x4 legs I was talking about is for when its laying down, you can see in the pics I just have some 4x4's cut to the right length and sitting in place right now. I want those to be 2x4's on hinges hanging from the bottom of the platform. So when its up, they fold down on the hinge and are not pointing out trying to hurt you.
    :cookiemonster:
  14. Jul 11, 2018 at 7:17 AM
    #294
    OldNeumanntapr
    Santa Maria, CA
    I got my hinges at Home Depot. They are only a couple of bucks for a pair.
    Greenbean and llamasmurf like this.
  15. Jul 11, 2018 at 7:29 AM
    #295
    Greenbean
    Zack
    Western NC
    I am really liking the idea of two separate hinged doors.
    Hmm
  16. Jul 11, 2018 at 7:31 AM
    #296
    Greenbean
    Zack
    Western NC
    Where did you get dem little d-rings?
    Guess they are strong enough for a fridge.
  17. Jul 11, 2018 at 7:34 AM
    #297
    llamasmurf
    Wes
    Northern Ontario
    I get them at work, they are stainless steel marine grade d-rings. Very sturdy little guys. I have put them all over my truck, I love them :cookiemonster:
    You can get them on Amazon I am sure.
  18. Jul 11, 2018 at 7:34 AM
    #298
    EatsInPDX
    EatsInPDX Well-Known Member
    This looks great! My only concern would be easy cleaning - maybe wrapping in a material that is non-slip and easy to clean up?
  19. Jul 11, 2018 at 7:35 AM
    #299
    llamasmurf
    Wes
    Northern Ontario
    Yea this is what I am thinking as well. For the dogs I have blankets and things that cover it all up, but you are right a non-slip easy clean surface would make it ideal.
  20. Jul 11, 2018 at 7:36 AM
    #300
    Greenbean
    Zack
    Western NC
    Awesome Thanks!!!
