Access Cab Door Adjustment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, May 12, 2010.
  1. May 12, 2010 at 5:52 AM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    I've done s few searches and found that it is possible to "adjust" the access cab doors? My problem is with the drivers side suicide door. when driving on bumpy roads i notice that the door seems to shake due to the flex of the truck and the upper latch semms to rattle like hell. does anyone have instructions on how to adjust this?
  2. May 12, 2010 at 5:58 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Try tightening the bolts that hold the door to the frame, the bolts for the door latch mechanism at the top and the bolts to the top latch.
  3. May 12, 2010 at 7:41 AM
    TOYOTA 09
    Maine
    and if tightening does not work is there any adjustment that can be made?
  4. Apr 6, 2013 at 11:48 AM
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    05/ 07,09/11Tacoma access cab 4x4
    Was looking at the problem on my Taco today. Close rear doors..put both hands on bottom and push in and out...note play. I stuck a piece of plastic 3/32 in thick to the bottom of door where it strikes the rubber stopper. Now the doors are firm!!!! Test pull before and after and note the difference. Just shim until tight!!!!
  5. Nov 24, 2014 at 5:56 PM
    TOYOTA 09
    Maine
    Anyone else have this issue...I still haven't fixed it.
  6. Nov 24, 2014 at 7:21 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    I get that too. I guess it's normal. You need to do what post above said
  7. Nov 24, 2014 at 7:23 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    This happened on my 2010. First weekend I had the truck I went down a fire road and lots of rattle, took it back to the dealer and they fixed it.
  8. Nov 24, 2014 at 7:23 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Adjust the latch at the bottom of the door to draw it in tighter.
  9. Nov 24, 2014 at 8:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    PM me your email address and I'll send you the service procedure to adjust the access door.
    eljedi68 likes this.
  10. Nov 25, 2014 at 3:43 AM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Adjustment is easy, just loosen bolts and realign.
    po35042 likes this.
  11. Nov 25, 2014 at 6:27 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That ^^^
  12. Oct 15, 2015 at 9:27 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Thanks for that info, my rear doors have been banging over bumps since day one, dealer ordered and replaced strikers but one of them is still loose and makes noise.
  13. Oct 15, 2015 at 10:05 PM
    Dustflap
    Dustflap Well-Known Member
    I tried this a while back and had no success. I loosened the bolts, but could not get striker plates to move in. I guess all the adjustment if any was already used up.
  14. Oct 16, 2015 at 12:57 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You may use a mallet to persuade them a little.
    As per the instruction for the Striker Plate Adjustment:
    Adjust the striker position by slightly loosening the
    striker mounting screws with a torx socket wrench
    T40 and hitting the striker with a plastic hammer
    (upper side).
    and :
    (lower side)
  15. Oct 16, 2015 at 10:17 PM
    Dustflap
    I did not have a plastic mallet, so I used a block of wood and a 16 oz. hammer after loosening the bolts. They would not adjust in anymore. I have heard the doors on the 2015 double cab trucks are not ajustable. Has anyone had any luck adjusting the 2015 access cab doors as described above??
  16. Aug 16, 2024 at 9:57 AM
    MrNachoTaco
    MrNachoTaco Well-Known Member
    Montana
    ‘09 Tacoma AC M/T
    Reviving this thread from the Before Times.
    Just bought an ‘09 AC. Bottom of the access door has a ton of play compared to the top. Going to try adjusting the bottom strike. If that doesn’t work, I’ll try to shim and/or tape it.
