Access Cab Door Sills
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedSox10NG, Sep 23, 2009.
  1. Sep 23, 2009 at 9:03 PM
    RedSox10NG
    RedSox10NG [OP] Active Member
    Nick
    Orlando, FL
    '13 PreRunner SR5 Spruce Mica
    Hey guys. Thinking about getting the door sill protectors for my Access Cab. Also thinking about painting the "Tacoma" part of the protector, if possible. Do you guys with the door sill protectors see this as plausible? Thinking about matching it to the exterior, Impulse Red :)
    Thanks!
  2. Sep 23, 2009 at 9:33 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    '15 TRDOR duck tape and ziptie edition
    stuff is lifted, removed, relocated, and/or painted
    I assume you're talking about the door sill protectors that come from toyota.
    It depends on how good of a painter/taper you are as far as painting the letters.
    They're just thin rubber-like material with adhesive backing. I was a little disappointed. They don't really cover enough to "protect" much in my opinion.
    I wish I had just gotten an adhesive backed plastic or rubber film from one of the industrial catalogs. For the price of toyota's stuff, I could've gotten enough material for a dozen trucks.
    http://www.mcmaster.com/#1867t22/=3rjpdd
  3. Sep 24, 2009 at 7:53 AM
    RedSox10NG
    Nick
    Orlando, FL
    Thanks for the reply totmacher! Which body style truck to you have the protectors in? I'm wondering if they coverage will be adequate for the Access cab body?
    Thanks!
  4. Sep 26, 2009 at 5:01 PM
    totmacher
    Daniel
    TN (memphis-ish)
    I've got access cab. It came as a 4 piece set. I'll get a pic here in a little while for you.
  5. Sep 26, 2009 at 5:09 PM
    RedSox10NG
    Nick
    Orlando, FL
    Greatly appreciated! Just curious how/what they look like installed.
    Thanks!
  6. Sep 26, 2009 at 5:19 PM
    totmacher
    Daniel
    TN (memphis-ish)
    pics attached. See that jagged edge near the front (left) edge? The metal eyelets on my work boots did that to it in under a year. That's as bad as it got though. Oddly enough, the paint is fine, boots didn't do anything to the paint under where it has ripped off the edges of the sill guard strip.
  7. Sep 26, 2009 at 5:39 PM
    RedSox10NG
    Nick
    Orlando, FL
    Thanks for the pics. I'm assuming you just eyeballed where to put these on the actual door sill?
    Mine are being shipped along with my bed mat, so I'm anxiously awaiting these 'protective mods.'
    Thanks for your help!
  8. Sep 26, 2009 at 6:31 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    After you take the plastic sill thing off, the "protector" butts up legnthwise against a long raised body seam, there are a few notches in the protector that line up with small bend in that seam. Real easy to see after you take the plastic sill off.
