Access Cab Door will not open?!?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by itsatacomathing18, Jun 29, 2011.
  1. Jun 29, 2011 at 11:45 AM
    itsatacomathing18
    itsatacomathing18 [OP] Well-Known Member
    Jordan
    Oswego, NY
    06 Toyota Tacoma SR5 Lifted
    Lift kit, 16" Helo Chrome Wheels, 33" GoodYear Wrangler MTR's, Blacked out tail lights, 7 inch Jensen Flip up monitor....
    I have an 06 Tacoma Access Cab, and after it was slammed shut when it was half open and the passenger door was slammed (brother and friend being stupid) it now will not open. Any ideas what to do, does the panel come off when the door is closed? Please help!
  2. Jun 29, 2011 at 11:53 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Try pushing the door closed while squeezing the handle to open the door. It's probably just jammed on the latch mechanism.
    Is there anything inside the truck pushing outward on the door?
  3. Jun 29, 2011 at 11:55 AM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    I just did new speakers in mine and now the doors are finicky too...
    Try this:
    stand by the door with a hand on the handle...as you squeeze the handle push the door frame, by the weatherstripping, toward the back of the truck...sometimes you have to wiggle and try a few times...but it should go.
    Once you do get it open, pull the skin off to have a look at what is wrong in there...
  4. Jun 30, 2011 at 7:38 AM
    itsatacomathing18
    Jordan
    Oswego, NY
    I'll try all these things today thanks guys!
  5. Jun 30, 2011 at 7:45 AM
    itsatacomathing18
    Jordan
    Oswego, NY
    It's like the handle isnt hooked up. I pulled the weather stripping and you can see when you pull the handle it's is supposed to pull on something else and that something else is pushed back and not moving...
  6. Jun 30, 2011 at 7:48 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    can you reach in there with something and pull what the handle is supposed to be pulling on?
