Access cab doors make noises from any bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doons, Dec 11, 2012.
  1. Dec 11, 2012 at 4:48 PM
    doons
    doons [OP] Active Member
    KANADIA
    2011 V6 4X4
    Okay so I've been getting the most annoying noises coming from my doors in my 2011 access cab truck. Any bumps makes a noise that sounds like a clicking. Has anyone experienced this?
  2. Dec 11, 2012 at 4:51 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I haven't but I would start by having someone drive while you are in the back listening for the noise to locate where it is coming from. I would also lube the door seal with a silicone spray. Good luck
  3. Dec 11, 2012 at 5:21 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    Just to be sure (because it's happened to me) : Make sure the seat belt isn't twisted up and out of position.
    Also, when the door seals are dusty, they can cause some noise as the body flexes.
    The last thing to check is that the doors are latching fully and that there isn't some mechanical problem inside the door.
  4. Dec 11, 2012 at 5:26 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    yea these trucks flex alot. . . . for instance my sig pic flexed the body so that my driver door fell about 1/2" when i opened it. as stated i guess the only way to keep that flexing quiet is to keep the door seals clean and slick
  5. Dec 11, 2012 at 5:53 PM
    doons
    KANADIA
    2011 V6 4X4
    Okay will try!
