access cab flex?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by carpdad, Feb 25, 2012.
  1. Feb 25, 2012 at 2:04 PM
    carpdad
    carpdad [OP] Member
    Hello. I'm looking at 2007 access cab. People here don't seem to mind the flex. But there isn't much info in the search. Does the flex become a problem, especially with doors latching properly? I'm in NJ, never go mudding or climbing rocks.
    I am looking for general Tacoma history, tsb, etc. on access cab flex.
    Also, this truck is 4 cyl, manual. Does it struggle with max. 500 pounds of building material in bed?
    Thank you in advance for any experience.
  2. Feb 25, 2012 at 2:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Never heard of the cab flex, not aware of any TSB on it. I can sometimes hear my doors creaking if I'm doing something to flex the suspension or frame. The doors all work just fine at 60K miles. The interior doesn't rattle. No hardcore off roading here.
    I have a 4cyl, manual trans 2009 Regular cab 2WD (non pre runnner) at work. It has plenty of power with at least 500 pounds in it at all times.
  3. Feb 25, 2012 at 2:19 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Eventually depending on how hard they are run all the access cabs will have some problem with the doors, might take longer for some than others but eventually it will come.
  4. Feb 25, 2012 at 2:24 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    :confused:
    I have an 07 access cab and I beat on it. all 4 doors still close pefectly with out any creaking. The only creaking I have is from my stock leafs which are shot from beating on them.
  5. Feb 25, 2012 at 4:50 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    This was one of my major concerns about buying an AC. Wondering whether Toyota reinforced the cab well enough for serious tweaking with no door pillars. Two weeks after I bought it I got into some very ugly shat in the desert. Twisted the hell out of it with two wheels in the air repeatedly. Other than the aforementioned creaking/moaning, no body alignment changes whatsoever. Still too new to see how it'll perform over time, but I was damned impressed with it after that little excursion to hell.
  6. Feb 25, 2012 at 5:03 PM
    oZmonKey
    oZmonKey Big Metal Hubajube
    Northern Colorado
    Black 98
    Unknown Spacer Lift.
    I think most folks wheeling their access cabs do it with the doors on.
    Take them off, ehh, might get some twistyness happening.
  7. Feb 25, 2012 at 5:06 PM
    Overlander
    Overlander Well-Known Member
    Over 100,000 miles never a problem with doors.:)
  8. Feb 25, 2012 at 5:16 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    My 5 lug Access Cab has hauled over 900 lbs to the dump and has no problems with the doors.
  9. Feb 25, 2012 at 5:21 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Never heard of an access cab flex issue.
  10. Feb 25, 2012 at 5:25 PM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    I never heard of such problem either.
  11. Feb 25, 2012 at 5:25 PM
    TnShooter
    TnShooter Well-Known Member
    07' TRD Off-Road, Auto
    STOCK
    I haven't had any door alignment issues.
    I haven't stress my body much, but I will say, I can hear
    the door seal and or something screech and crunch when I
    drop off or go over a rut/dip/bump.
    But it is really only noticeable when I go over it diagonally.
    Like dropping one wheel over at a time. That stress the truck more and you can hear the door seal or something screeching. NEVER, as of yet have I had a problem.
    I don't intentionally offraod, but I do use it to cross farmland ect. I use my truck as a truck. But not for rock crawling etc.
    I never really thought of it warping the body and causing alignment issues etc.
    My concern is more toward the windshield. I'd hate to break the seal on that and cause it to leak? Can this even happen?
    I have a 2007 Access-Cab.
  12. Feb 25, 2012 at 5:28 PM
    Thorpedo26
    Thorpedo26 Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    my 4 cyl has seen 1200 lbs in the bed of dirt and or rocks, no issue besides looking like im going to do a wheelie
  13. Feb 25, 2012 at 5:30 PM
    von0777
    von0777 Well-Known Member
    tn
    2013 4x4 trd
    i got 149000 door are good.i haul ac units 2.7 4 cy 5 speed accdsscab
