Access cab vs DCLB frame
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crazybeard, Nov 19, 2021.
  1. Nov 19, 2021 at 6:32 AM
    crazybeard
    crazybeard [OP] New Member
    I've got a lead that I am considering purchasing for a crashed 3rd gen that needs the frame chopped off in front of the front leaf mounts and a new one attached. Having some trouble finding a DCLB frame to chop, but there's plenty of access cabs.
    Anyone know if the frames are similar enough? It seems that given the bed length and such it would make sense the mounts for fuel tank and such would probably be similar, especially how Toyota likes to do things the same as much as they can and the difference would be under the cab itself but I don't know for sure.
    Anyone have some knowledge with this?
  2. Nov 19, 2021 at 6:34 AM
    Clymber
    Clymber Well-Known Member
    Vermont
    Trd
    Access cab is same frame as DCSB. That's all I can help with
  3. Nov 19, 2021 at 8:41 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    From what I remember reading on here you can’t weld the frame because Toyota uses high strength steel and welding messes with the temper. I think that you would have to replace the entire frame.
  4. Nov 19, 2021 at 8:55 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Apparently many people think the Tacoma frame is glued together. Heating the frame to bend or straighten is to be avoided. As far as weakening the steel, cutting and welding in a section will not be any different than when Dana Corp or whoever builds Tacoma frames today welds them.
    crazybeard[OP] and zoo truck like this.
