Access Cabs on 885s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, Jul 12, 2016.
With my 885s, should I...
  1. Add 1/4" spacers
    6 vote(s)
    42.9%
  2. Leave out the spacers
    8 vote(s)
    57.1%
  1. Jul 19, 2016 at 9:29 PM
    Big Sky Country
    Big Sky Country Well-Known Member
    Montana
    2013 DCSB TX Pro
    Century topper, OME 885x, Nitrochargers, full Dakars
    I think the stance looks great man, contemplating removing an overload on my setup as well. Shitty deal about the MTB crash, had a pretty good one myself about this time last year!
    Pigpen[OP] likes this.
  2. Jul 20, 2016 at 6:11 AM
    K.Ray
    K.Ray Well-Known Member
    East TN
    2016 Toyota Tacoma TRD Off-Road, 6sp Manual, Quicksand
    None
    885x coils up front with bilstein 5100 set to .85"
    wheeler's 3-leaf AAL in rear
    tires are 235/85r16
    Below photos were taken at expo weight with the following gear: ARB bumper, Warn VR10000 winch, RTT, 2m awning, sliders, and a truck bed full of multi-week camping gear.
    The lift was approximately 2"-2.5"
    [​IMG] [​IMG]
  3. Jul 20, 2016 at 10:14 AM
    TRDMountaineer
    TRDMountaineer Well-Known Member
    Ripley, WV
    2015 AC TRD Sport MGM 6-spd S/C
    TRD S/C, aFe Stage-2 Intake, Magnaflow 15315, Leer 100XQ w/ Tracker II Rack, General AT2 265/70R17, OEM skid, TRD FJ caps, Wet Okole Realtree seat covers, TRD grey shift knob, Weathertech floorliners, Weathertech window visors, Salex glove box+console organizers, Grid-It console lid mod, Lamin-X amber fogs, Craven Speed A-pillar phone mount, Debadged
    Looking for some input here. I'm looking for 2-2.5" up front, additional weight on the truck over stock includes supercharger and OEM skid. 884 or 885 with 5100's? (Access cab)
  4. Jul 20, 2016 at 11:01 AM
    K.Ray
    East TN
    None
    You might get 2.5" with 885 coils if you're lucky. Doubt you'll get anywhere close to that with 884s. We typically only recommend an 885 or 887 coil for anyone looking for lift. The 886 will step up your spring rate and you dont want that on a mostly stock truck. 885 with bilstein 5100 at .85" or spacers will get you 2.5".
  5. Jul 20, 2016 at 11:15 AM
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    885
    Consider spacers too with that extra weight. What skid do you have? You typed OEM... Did you mean IFS?
  6. Jul 20, 2016 at 1:32 PM
    TRDMountaineer
    Ripley, WV
    Original Equipment Manufacturer... Just the stock TRD skid and yes it's IFS. Not much weight to it (aluminum).
  7. Jul 20, 2016 at 1:36 PM
    Pigpen
    Dan
    Northwest Montana
    Okay, so no real weight there. You'll get 2"+ from 885s without spacers. Without the S/C, you'd get nearly 2.5" without the spacers.
  8. Jul 21, 2016 at 9:53 AM
    TRDMountaineer
    Ripley, WV
    Sounds like 885 is worth a try. Trying to stay flexible with tire options and not have too much lift for a 265 tire (32") and then maybe add a spacer later on if I bump up to 285.
  9. Jul 21, 2016 at 11:09 AM
    Pigpen
    Dan
    Northwest Montana
    A tire that's 285 wide will still probably require a cab mount chop.
